Old 05-27-2013, 09:37 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Default Annoying squeeking noises in the truck after lift install
I have a 6" rcx , bils at 1.4 , 1.25 body lift , there were no squeks or noises until after this weekend , took the truck on 430 km run , both ways so about 860 kms round trip , now i have squeking noises that can be heard inside the cab with the windows up , i have went right therew the rear re torqued everything . the noises are still there and driving me crazy ! And suggestions where to look for the issue ?
Old 05-27-2013, 11:42 PM
When does it happen?
Upon acceleration and breaking and going over bumps?
Probably the body lift.
If this is the case, it is the reason why I removed mine.
I'm anal with that stuff. Now I have a rear squeak in the back that dealer could not find
They said that's a normal creak.
Like wtf?
Old 05-28-2013, 10:45 AM
RAM303's Avatar
RAM303 RAM303 is offline
Vehicle: 2009 Dodge Ram
Rep:26
RAM303 is on a distinguished road
I get that too with my 09 pro comp lift. I get a can of lubricant and crawl under the truck and hit every bushing I can find. I even had my wife hop up and down on the rear bumper so I can find it. It goes away until the undercairage gets wet from rain etc....then it slowly comes back and I repeat the process. Just did it yesterday as a matter of fact.
Old 05-28-2013, 01:02 PM
Quite annoying, but thats a body lift for you
Old 05-28-2013, 08:33 PM
Rep:94
Got this all fixed up for now , sprayed the upper spring mounts on the blisteins with some wd/40 and the squeking went right away also sprayed all the rubber bushings .
Old 05-28-2013, 10:45 PM
Glad you found a resolution
Old 05-28-2013, 10:55 PM
Rep:94
e you
ya me to it was annoying ! any chance you could get me a quote on these spyder headlights ? this is the part # PRO-YD-DR09-CCFL-BK
Old 05-28-2013, 11:40 PM
e you
Ill message you tomorrow bout this
