Old 05-28-2013, 12:44 PM
Rich859's Avatar
Rich859 Rich859 is offline
Rep:309
Rich859 is a jewel in the roughRich859 is a jewel in the roughRich859 is a jewel in the roughRich859 is a jewel in the rough
Default 2009 Dodge ram LED tailgate bar not working properly
I have a 2009 ram and the led tailgate bar came from ebay. I bought one for my older ram and it worked fine. Now this one for my 09 only works with the headlights off, with my headlights on the only thing the light bar does is turn on the runnning lights, no brakes or turn signals. Is there anything you guys can think of as to why this is?
Thanks,
Richard.
Bully's Performance Sponsored Truck
Too many mods to list. Full list can be found on my profile.
Old 05-28-2013, 02:51 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Have you tried it independent of the truck to see if each part of the light bar works, basic ground and + wire to each pin on the connector. How are you installed? on a "T" connector to the Trailer harness or direct?
Old 05-28-2013, 03:53 PM
Rich859's Avatar
Rep:309
I have attempted both. All of the functions work and receive power when the headlights are off, when on the only one getting power is the running light.
Old 05-28-2013, 06:51 PM
Vehicle: .
Rep:4373
To me it sounds like there is some sort of polarity mix up, but without trying to trace it its hard to tell, If your using the trailer plug to power up the unit, I would plug the basic stop lights only and try it, then add the turn signals and then the parking lights, see which one is causing the issue and then take it from there, its either defect of there is something screwy with the wiring.
Old 05-28-2013, 08:25 PM
Rich859's Avatar
Rep:309
Ok, I'll give that a try and hope that gets it to work. Thanks for the tip Asur!
Old 05-28-2013, 09:25 PM
Vehicle: .
Rep:4373
Keep us posted on what you figure out.
Old 06-01-2013, 09:41 PM
Rich859's Avatar
Rep:309
Well I tried to use each wire one by one and they all work headlights off, then one by one with headlights on and only the running lights work. I just ordered the LED Glow tailgate bar, we'll see if that one works over the generic one I had
Old 06-02-2013, 10:00 AM
Vehicle: .
Rep:4373
Cool, let us know how that turns out, best of luck
