Old 05-28-2013, 07:28 PM
landozer18's Avatar
landozer18 landozer18 is offline
Vehicle: 2012 Ram 1500
Trim Level: Gladiator package
Color: Black with chrome
landozer18 is on a distinguished road
Default Fuel additives
Anyone running any additives? If so which and why?
Old 05-29-2013, 02:22 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
I typically use Stabil Marine formula (blue/green in color) with most tank fills to combat the ethanol related problems. Every 3K I add Seafoam or Techron to the fuel, to clean any crud build-up in the fuel system, especially the injectors.
Old 05-29-2013, 08:07 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3248
PaulMys has disabled reputation
I thought additives were a big no-no?
Old 05-29-2013, 08:13 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Octane boosting additives are a big no-no. There are lots of other ones that are good such as injector cleaner, seafoam, etc. They're meant to clean your fuel system and combustion chamber.
Old 05-29-2013, 08:17 PM
Jan 20. Sad Day
Vehicle: no car
Rep:3248
Ahhhhhh. Thanks Brandon!
Old 05-29-2013, 08:48 PM
fast31's Avatar
fast31 fast31 is offline
Vehicle: 2012 Ram 1500 Sport 4x4
fast31 is on a distinguished road
Im curious to know why octane boosters are a "no no"...
Old 05-29-2013, 09:16 PM
joewally joewally is offline
Vehicle: 2011 Dodge Ram
joewally is on a distinguished road
i use stp ethanol cleaner in a green little bottle. Its suppose to clean the crap left behind after burner the shitty ethanol.
Old 05-29-2013, 10:49 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
Most are oil-based products that either don't combust completely or leave residues in your fuel track/injectors. Some are chemicals that interfere with the catalyst process or my personal favorite is the fuel oxidizers that create more oxygen in the fuel to increase combustion
Unless you're adding something like torquo that is high purity fuel that must be blended down then you're going to be wasting a lot of money. A lot of 'octane' boosters claim to raise octane 3-4 points... this means .3-.4 octane, not 3-4 like people believe.
Kurtis
Old 05-29-2013, 11:59 PM
Rep:2026
They are also very bad for all the seals and O-rings in your fuel system. We were running it in my dads prostreet racecar for a while (on the street, not racing) and it ate all the fuel in the fuel cell which in turn clogged the whole fuel system. Once that happened we took apart the entire system and found all the seals in the pump, filter, regulator, etc to be completely dried up and not working properly anymore. Now that I look back on this it doesn't surprise me that it happened at all. If you spill octane boost on your hand it dries out your skin instantly.... It's just not good stuff. You're better off buying the right octane fuel at the pump.
Old 05-30-2013, 03:11 AM
landozer18's Avatar
Ok all this said how do we make sure we have the right octane?
