Old 05-28-2013, 07:41 PM
itsmesukkka itsmesukkka is offline
Vehicle: 2012 Dodge Ram1500
itsmesukkka is on a distinguished road
Default Reverse LED Issues Please Help
Hello,
Im having a weird issue where I had a pair of led reverse bulbs (the white lights in the taillight that go on when you put the truck in reverse) in my 2012 ram 1500 and for some reason after having it for several months with no issues I noticed the right one was dimmer than the left, once taking out the bulb I saw that only one of the LEDs was actually lit up, so I thought the bulb just went bad, I then ordered a new pair plugged them in and they worked great for a couple days and then the same thing happened to the new bulbs, is there any advice you can give me to fix this issue.
Old 05-28-2013, 09:27 PM
Asur Asur is offline
Vehicle: .
Rep:4373
What kind of LED Bulbs are they, are the bulbs you got in replacement the same as the ones you had in there?, same make, same seller? I have had mine in for over a year and no issues. If you move the good bulb over to where the bad bulb is, does the same thing happen?
