Place your Ad Here!
Old 05-28-2013, 07:57 PM
SScott's Avatar
SScott SScott is offline
Vehicle: 2001 Ram 2500 4X4
Rep:19
SScott is on a distinguished road
Default 4x4 Not working...
I looked for a sticky and searched but my searchfoo is really weak. Is there a thread on troubleshooting why the 4x4 will not work? I have an 01 2500 Ram with 5.9 gas and an auto trans. Thanks!!!
Old 05-28-2013, 10:39 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Well, if your light is out as well, check the vaccum lines on the front of the transmission crossmember on the drivers side, they have a union there, with a silicone tube covering the unions, easily pulled apart by snowbanks, brush, whatever. The vacuum lines may be disconnected elsewhere, if not there. Good luck!
Old 05-29-2013, 09:26 AM
SScott's Avatar
Rep:19
The light is out. I will check for vacuum line leaks, the guy I got the truck from just put a new drivetrain in, it is possible he never hooked it up. I had no idea what to start looking for. Thank you Screamin!
Old 05-29-2013, 11:14 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Yep there should be a green and a red/orange vacuum line running down to the actuator on the front rear from the passenger's side of the engine. I'd start there.
Old 05-29-2013, 11:25 AM
SScott's Avatar
Rep:19
Thank you Warlock! I can't wait to get some time to check now, I have a nice winch and mud tires and have been afraid to hit any trails (this beast is heavy!).
Old 06-05-2013, 09:26 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 06-15-2013, 03:29 PM
SScott's Avatar
Rep:19
Thanks everyone! It was the vacuum line that runs up the firewall by the dipstick, I fixed it and the 4 wheel drive works great now! No light but it engages and works fine (I tested it the fun way).
Old 06-17-2013, 09:47 AM
Wh1t3nukle's Avatar
Rep:57
Good job and great of you to reply back so ppl with similar issues can follow.
For the light, you just may have lost or its disconnected, the wire for it. No biggie as it's actually not long enough if you have 3" lift... lol
If you want to find it, then go to the front axle and you'll or find another wire with a harness plug on it that also comes from the CAD. This is where you found the vac lines. This wire gets plugged in at the bottom of radiator, passenger side.
Old 06-17-2013, 09:50 AM
SScott's Avatar
Rep:19
I have more than 3" of lift so that is probably it, thank you once again Wh1t3nukle!
Old 06-17-2013, 09:53 AM
Vehicle: 95
Rep:1776
There is also a switch on the TFC that illuminates the light when the 4 wd is engaged on my truck. It may be unplugged or need to be adjusted.
