Old 06-17-2013, 09:55 AM
SScott's Avatar
SScott SScott is offline
Vehicle: 2001 Ram 2500 4X4
Rep:19
SScott is on a distinguished road
How would you adjust it if that is it Warlock? I have a leak somewhere on the TFC and am going to look closer at it. Thanks!
Old 06-17-2013, 09:58 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
There is also a switch on the TFC that illuminates the light when the 4 wd is engaged on my truck. It may be unplugged or need to be adjusted.
If you have a 95 as it says in your info, then it does not apply to his 2001.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 06-17-2013, 10:05 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Oops, I just went out and looked. Mines a manual and I was thinking that the NSS was it for some reason.
It's weird though because in the cold I can disengage the 4 wd and the light will stay on for a second so it is probably vacuum activated. But I'm not sure to tell the truth. I already forgot more than some guys will ever learn
Sorry.
Old 06-17-2013, 10:07 AM
Vehicle: 95
Rep:1776
Calm down, it was an honest mistake. I don't want him looking for something that doesn't exist either. I wasn't trying to intentionally mislead him. I have changed quite a few things on the truck and updated it and just couldn't remember if that'd been done too.
I apologized
Old 06-17-2013, 10:09 AM
Wh1t3nukle's Avatar
Rep:55
You made the mistake. Simple as that. He and others could do the same thing. We are both here to help catch mistakes, right?
SScott's Avatar
Rep:19
No problem at all Warlock. I am VERY grateful for the help! Don't tell anyone but I am a Ford guy who just got his first ever Dodge so it is like being a newbie all over. =D
Old 06-17-2013, 10:21 AM
Vehicle: 95
Rep:1776
As I had said, yes I made the mistake, I was wrong, I submitted an erroneous supposition, and for that I am truly sorry.
The only reason there is 6 minutes between my posts is because I went out to double check because I know there's a difference between 95-97/98-99/2000-2001. It'd be different if I had just said it and left it at that.
You have my unending gratitude for being here on the site and immediately calling me out on my mistake and pointing it out while I was outside verifying whether what I had said or not was true, and for that I thank you. Simple as that.
Thank you Thank you Thank you
(not to mention that "be right back" was under 15 characters so it didn't post while I was out looking, if only you'd been here to point that out to me too)
Old 06-17-2013, 10:43 AM
Wh1t3nukle's Avatar
Rep:55
At least you actually go out a check stuff AND able to report with high confidence on "how" you checked it. I'm confident that you'll catch me with a mistake here and there as well. There are all these slight nuances on these rigs and one can easily mix 'em up.
We don't need no stinkin 4wd light!
on me
Old 12-04-2013, 12:53 AM
RamEarthquake RamEarthquake is offline
Vehicle: 1998 Ram 1500 4X4 Club Cab SB
Trim Level: VIN says Laramie
RamEarthquake is on a distinguished road
Well it's been six months since a post was made on this topic and I thinks it's time to fix that.
I am new here, and a new Ram owner. I have had a ton of Durangos, but I finally got my truck!!
Issue is (issues ARE, but I will cover the other stuff elsewhere and later) I have had the truck for two weeks, just put on Cooper ATP LT265/75-16's and tried to use the 4WD (4 High). The light comes on, I can feel the transfer case change gears, but no front wheel spinny spinny. I put it in 4 Low and the rpms went up at low speed like it should, but still no front wheel gription. I have read through this post and others and understand that there is a vacuum line, but if the light comes on then the vacuum line is working, right?
Any help would be great. I have already been using the vast knowledge from here for a week or so. Thanks in advance!!
Old 12-04-2013, 01:53 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is online now
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
Just becasue the vacuum diaphragm is moving the actuator switch in the axle doesn't mean the engagement fork is operating correctly. On the passenger side of the front axle is where the actuator motor is located. make sure its working properly. I had the same symptoms on mine and ended up running a pto engagement cable to convert it from vacuum to mechanical.
