Old 05-28-2013, 09:28 PM
Nck's Avatar
Nck Nck is offline
Vehicle: 2013 Ram 1500 Laramie
Rep:74
Nck will become famous soon enough
Default Possible bad slip yoke?
I've been reading a lot around the internet on this. But for years now when I put my truck into gear, it clunks every time. and when I let off the gas, when the truck slows enough it will shift and will have a loud clunk.
And also lately (only when going into third gear) when I hop on the free way. The truck seems to have a tranny slip before slamming into gear and jerking forward. I don't think it's the trans anymore, but rather this slip yoke.
Old 05-30-2013, 05:12 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Well... Apparently no one on here even has a clue what a slip yoke is.
But anyway. My problem has turned out to be the complete front CV drive shaft that connects to the t-case. I'm going to replace it and see if my problem goes away. Cons--- The part cost $300
Old 06-05-2013, 09:24 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
If you are talking about the slip yoke on the rear of the tcase, then it makes sense no one responded as that would not have been the cause of the clunk. The slip yoke just transfers load.
Did they give you/show you the front CV being crappy? You probably could have got one cheaper from the junkyard, the whole driveshaft. I guess you found out the problem is the front DS by removing it and driving to make sure the clunk is gone?
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
