Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 05-29-2013, 12:00 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
TLC John is on a distinguished road
Default New Air Compressor Option
Please check out our new air compressor option for your TLC air suspension.
We are offering a portable 12V 100 psi Pittsburgh Automotive compressor with built-in gauge. The great thing about this compressor is its low price and incredible performance for all applications including airing up tires (neither the wired compressor kit that TLC sells or the WirelessOne can do that). This is a gearless direct drive compressor that adds up to 25 liters per minute.
This compressor includes a 5 ft coiled air hose, brass quick coupler, 10 ft power cord with cigarette plug, 2 inflator nozzles, needle valve, tire gauge, 15 amp fuse and convenient nylon carrying case.
If you want an inexpensive, all-around compressor that you can take anywhere and use with your TLC system and other recreational uses, this is it.
$39.00 when purchased with a TLC system.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with
= Copyright a Network Site =Ad Management by RedTyger
