Old 05-29-2013, 01:28 PM
dewzram dewzram is offline
Vehicle: 2000 Dodge Ram 1500 4x4 QC
Rep:12
dewzram is on a distinguished road
Default Intermittent Stalling - Split Second
Hello -
I've had my Ram, which is a 2000 1500 QC 4x4 with the 5.9L and for the past 3 years (since I've owned it) I've had a slight intermittent stall. It is very random when it occurs, sometimes not at all, or sometimes 5 times a day. can happen at idle, or while driving 75 mph. It will stall for a split second, the RPM's cut out and then as quick as it does it, it comes back like nothing happened. It'd never killed or stalled itself out, but this stall on the highway can be a bit alarming and startling if it hasn't occurred in a while. I've replaced plugs, cap, wires, and rotor twice now and spent hours routing plug wires so they are not touching at any point, still hasn't done a thing for this miss or stall. I've replaced an 02 sensor a while back that threw a code. I'm not experiencing severe oil consumption or pinging. Just curiuos as to what my top culprets could be at this point? Seems like most likely could be vacuume leak of some sort or fuel delivery/management issue right? Intake Gasket possibly? Or Fuel Pump/filter issue, or relay possibly? I'm just kinda at a loss since It's never thrown a code or left me stranded, so been very hard to pinpoint and fix.
Any thoughts or suggestions from those that have had the issues, will be much appreciated! Thanks!
Old 06-06-2013, 09:29 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Quite aggravating when climbing a hill, especially with a trailer, isn't it!! I have the same problem with my 02 v-8 explorer, the fixit guy that I use tells me it's the crank sensor, probably with a hairline crack? I haven't yet gotten around to taking his suggestion and changing it to test his theory. Years ago, this same thing was going on with another buggy of mine, and it was a bad bonding wire to the frame from the engine, seems all that iron bolted together sometimes isn't enough for the ignition to work quite right, all the time. Just my two cents...
Old 06-07-2013, 12:05 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
Originally Posted by dewzram View Post
Hello -
Sorry I didn't see your thread till now.
I think you are on the right track. Fuel pressure (check at the fuel rail schrader valve) should be b/t 45-49 psi.
Yes, track down any vacuum leaks. Find all the lines. Does your HVAC work fine? If not then that confirms a vac issue of some degree. I mean running A/C and it does not stay cold or defroster setting is always operating.
Check all your fuses. Pull them out and look.
The next things could be crank position sensor (unlikely though w/o more info) and/or cam position sensor (located on the underside of dizzy).
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 06-07-2013, 10:42 AM
98rumblebee's Avatar
98rumblebee 98rumblebee is offline
Vehicle: 1998 Dodge Ram 1500
Color: Yellow + Black
98rumblebee is on a distinguished road
Yeah I know a guy who had the same sort of problem, it was the fuel line that was bad. But that one would stall completely and need to be restarted...
Put a good dip in
Old 06-07-2013, 01:45 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Your description sounds like you're actually saying it's heart skips a beat, if that's an accurate example.
I'd check the plug at the coil in addition to the other suggestions.
I don't want you to have a laundry list of things to consider but it seems there are some very valid posts so far.
Old 06-13-2013, 08:51 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
I put my money on the CPS, highly known to cause a problem like this.
Old 11-11-2013, 05:34 PM
Rep:12
Default Ooops!
Sorry for the late replay guys, for some reason I thought I'd already responded but apparently never did, so my apologies.
I still have not found the cause of this issue. I did try fuses and vacuum lines, but found nothing wrong there. I did want to mention my cruise does not work and has never worked since I've owned the truck. The "Cruise" light will not even come on, so I'd say it has to either be switch or vacuum leak possibly right? Not saying it's related to my "stall" issue, but if it ends up being vacuum, I guess it could be related. I have no issues with HVAC system at all, air blows ice cold and heat blows hot, no blend door issues either.
I just hate that it won't throw a check engine light for this. Anyway, thanks for the help and I'll start in on this and see if I can't find the culpret.
Old 11-13-2013, 11:48 AM
Vehicle: 95
Rep:1776
Panhead makes a valid point...but I pondered this awhile ago and was thinking that I'd check the body ground on the back of the engine to the firewall.
Old 11-14-2013, 01:14 PM
Rep:12
Thanks Warlock! I'll certainly check that ground as well since I haven't examined that yet. I'm going to just buy a CPS since they are only about $45 at Autozone and just see if I get lucky.
