Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Place your Ad Here!
Old 05-30-2013, 06:02 PM
djkicks djkicks is offline
Vehicle: 1996 Dodge ram 1500 5.2L 4x2
djkicks is on a distinguished road
Default Fuel pressure test fitting
I did a search and I couldn't find this specific info. I have a 1996 2wd 5.2L 1500 and I need to test the fuel pressure but I cannot seem to find the fitting. In my Yukon, it was very easy to locate.
Sorry to bug everyone with such a simple request but I have a small window of time to do this and I'm just not finding it.
Thanks,
DJ
Old 05-31-2013, 11:49 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Some people say their units don't have the test port, on both of mine, the port is on the drivers side rail over the head, pointed straight up. If no test point you would need to get out your tubing cutter and a compression tee, and install a schrader valve on the branch. (you would need two cuts if you cut into, over the eng, not recommended) I would probably cut under the truck somewhere, then you could do as you wished, with a schrader valve, a pvc tee, fuel hose good to at least 50 PSI (system pressure should be about 40 - 43 max)and 4 hose clamps to go over the hose and barbs .
