Old 05-30-2013, 09:29 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default Lift kit and Tires
Ok i know there have been many posts about it including some from me, but i just want to make sure. I am planning on getting a 4 inch lift and the 285/65r20 bfg a/t on stock rims. I have the 3.55 gears and will be off road/ mudding a little bit. How will the almost 35 inch bgf be with my gears? Is it ok with to run this combo? I am also looking into a Bully Dog tuner.
Old 05-30-2013, 10:20 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
You'll be fine. I'm running 35" Toyo MT's which are significantly heavier than your BFG A/Ts and it's not bad at all. And that's with a 4.7. You can't check out my review on the tires for more info on drivability and MPG etc, link in my signature below.
Old 05-31-2013, 08:20 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you're gravy baby.
might see a little bit of an MPG hit. But you gotta pay to play, that's my motto.
Old 05-31-2013, 03:17 PM
Trim Level: express
Rep:43
you're gravy baby.
Sounds good to me! Thanks guys for the help.
