Old 05-30-2013, 10:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Default Any plumbers here?
I've trying to plumb up a shower valve and can not get the threaded fitting from the cpvc to the brass valve to not drip. I've redone it 3 times now. I have done some other plumbing projects, some copper, some cpvc, and a good amount of pvc, and never really had any issues. This one is kicking my butt.
First time both the hot and cold supply dripped at the threaded fitting. I redid it with more teflon tape(I'm using tape only...have never tried dope), then second time the cold was good and the hot supply dripped at the same spot but slower. I did that side a 3rd time with even more tape(we're talking about ~7 wraps now) and I think it's still leaking. It seemed dry at first but after about 1-2 hours I went back and there was a little water there, although not enough to form a drip. I wiped it all dry and will see if it comes back.
I'm at a loss....
Here's pics of what I"m dealing with. I'm also using the preferred composite fittings(not all plastic)
http://i1133.photobucket.com/albums/...ps8706f484.jpg
http://i1133.photobucket.com/albums/...psb4db2523.jpg
http://i1133.photobucket.com/albums/...psd2c6bbcb.jpg
Sean
Old 05-30-2013, 10:42 PM
Joekrooz's Avatar
Joekrooz Joekrooz is offline
Vehicle: 2012 Dodge Ram
Trim Level: 1500 Express CC 4x4
Color: True Blue Pearl
Rep:122
Joekrooz will become famous soon enoughJoekrooz will become famous soon enough
I'm not a plumber but I do a lot of irrigation repairs and the occasional plumbing job. Try using 2-3 wraps of Teflon, in this case more is not better. If that doesn't work try 2-3 wraps of Teflon with the blue brush on thread sealer. Good luck.
Old 05-30-2013, 10:46 PM
snrusnak's Avatar
Rep:1385
I started with ~3 wraps. It leaked bad(fast drip). Then went to ~5 wraps and the cold side stopped but hot still leaked. Went to ~7 wraps and I think the hot is still leaking.
I'm thinking about trying pipe dope. Not sure if I should just redo all the fittings with it though...
Sean
Old 05-30-2013, 10:49 PM
Joekrooz's Avatar
Rep:122
Not to be a wise guy but you are wrapping clockwise around threads. Sorry I gotta ask!
Old 05-30-2013, 10:50 PM
snrusnak's Avatar
Rep:1385
Yes I'm wrapping in the same direction as the threads, so when I tighten the fitting it goes with the tape, not against it.
Sean
Old 05-30-2013, 10:54 PM
Joekrooz's Avatar
Rep:122
I figured that, you never know. That would frustrate the hell out of me. Maybe someone else can give some better advise. Sorry I couldn't help you.
Old 05-30-2013, 11:00 PM
snrusnak's Avatar
Rep:1385
I appreciate the help. I've never fought a leak like this. I'm considering soldering copper off the valve then using threaded adapters to the cpvc. But that's still a threaded connection...
I'll probably try pipe dope. 4th times a charm??? lol
Sean
Old 05-30-2013, 11:57 PM
70x7's Avatar
70x7 70x7 is offline
Vehicle: 2008 QC HEMI
Rep:34
70x7 is on a distinguished road
dude, you need the pipe dope. teflon is only good for so much...
2008 1500 QC HEMI--
Spectre Intake*Flopro Max Muffler*Superchips Cortex*Bilstien 5100*Pioneer AVH-X7500BT*Magnaflow Ypipe*Viper Alarm*85mm Throttle Body
Old 05-31-2013, 01:17 AM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
I'm not a plumber either, but I had a similar problem that took me forever to figure out.
My problem was that my brass fittings had a burr (looks like someone cross threaded them at Ho Depot), and I didn't notice until I installed them.
In the end I had to replace the fittings with new ones, and all was good in the end.
Sorry can't be more help, but just a suggestion.
Old 05-31-2013, 08:14 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
Use pipe dope, and get some new fittings. Those Lowes/Home Depot fittings are usually crap. I use shark-bite now, a little more money, but you don't have these problems
