Any plumbers here? - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-21-2013, 04:51 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Interesting snur. I was informed that it was a 15 % loss in pressure for every 90 bend. Even someone brought in a demo. It wasn't for pex but some new toilet design on making the flu s h more efficient, but I took it hy the same principle (the demo changed the water flow pattern if I recall) ill have to look back into the reduction loss at 90 bend. If what you are saying is true
Yep that's the difference between pressurized flow and non pressurized flow. The bends certainly have a large effect on flow with non pressurized systems. That's why drainage pipes have "sweeped" or gradual bends, instead of hard bends like pressurized systems have.
Sean
Old 08-21-2013, 06:13 PM
Crobber's Avatar
Crobber Crobber is offline
Vehicle: 2001 Dodge Ram Sport 4x4
Trim Level: Sport 4x4 SLT
Rep:26
Crobber is on a distinguished road
I agree with drainage systems. Looking for clarification. Are you stating that you will get equal loss using two 45 vs one 90 bend or you have less loss using one 90 bend.
"You can't just give up hope and walk away, Cause when you do that then there is no hope at all."
Old 08-21-2013, 06:23 PM
snrusnak's Avatar
Rep:1388
I don't know that I know the answer to that honestly. Are you referring to pressurized or non pressurized?
I would have been able to answer that question at one time, but after school I never really use this stuff as I went into a different field so don't remember it all.
Sean
Old 08-21-2013, 07:10 PM
Crobber's Avatar
Rep:26
Pressurized.
The basic idea of pex that was taught to me is that if you can weave from point a to b with reducing the numbers of turns and reducing the degree of turns I.e. a 90 bend will become a gentle long 90 bend (by flexing the pipe) over a few feet rather than that sudden 90 bend done iver a matter of 2-3inches. You will reduce the amount of pressure lost. Thats where I got my principle behind pex its a smaller pipe size for size lets say vs pvc but has the potential of flowing the same amount of water as you are able to reduce the amount of joints used which in turn reducing the lost psi at the faucet end.
Old 08-21-2013, 07:18 PM
Crobber's Avatar
Rep:26
Dont misunderstand, if I am incorrect. I am open ears. I never really had a side by side comparison.
Old 08-21-2013, 07:49 PM
snrusnak's Avatar
Rep:1388
Well I personally don't know for sure but I don't believe that was the whole reasoning and benefit of PEX. I believe the benefit was just to have a truly flexible piping system. Not necessarily because it limits pressure drops from hard bends. As I said before pressurized systems have little pressure drop from hard bends, it's basically negligable. They call it a "minor" loss, as opposed to a "major" loss. If it were not pressurized then it'd be a problem.
I really think PEX was just a different sytem someone came up with to make a flexible system, and in all honesty, in the end it is just their invention to make money lol. Just like everything else. PVC was the same, it was a new invention of a system to use in lieu of copper. I'd say all three systems have benefits and drawbacks, and all will work fine overall. I tend to use whatever is coming out of the slab just for simplicity and uniformity. If I was plumbing from scratch I'd use either copper or pvc, though it'd likely be pvc as it's substantially cheaper. I'd just use copper at tubs for the strength and anywhere the pipe passed through mortar, masonry, concrete, etc (unless covered/protected) as cementitious products react poorly with copper and will degrade the pipe.
Sean
Old 08-24-2013, 12:48 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
PEX was made to take place of copper and pvc. its cheaper and faster to install. PEX does not break if it freezes as it expands and contracts with temperature unlike copper and pvc. Copper is $20 for a 10' pipe where PEX is $25 for a 100' roll. Yes, the sharkbite fittings are more but you use less fittings since pipe is flexible, and as far as the long bends...false, PEX can be bent is a tight U shape about 6" diameter as it is used between floor joists for heating and so on.
I Am Groot !
Old 08-24-2013, 05:07 AM
wolfman01 wolfman01 is offline
Vehicle: 2013 Ram 1500 QC 4x4
Trim Level: Bighorn Edition
Rep:126
wolfman01 will become famous soon enoughwolfman01 will become famous soon enough
PEX was also designed to be a no-tool installation. The fittings snap into place with no soldering or gluing, and they have fittings that will also fit over copper and PVC.
2014 Chevy Spark (3k)
2013 Ram 1500 Quad Cab 4x4 Hemi 8 speed (7k)
2004 Saturn ION Redline (9k)
1995 Tiffin Allegro Bay (46k)
1989 Oldsmobile Cutlass Cierra (97k)
Old 08-24-2013, 07:17 AM
snrusnak's Avatar
Rep:1388
Well I agree PEX suppliers want it to replace PVC and copper. And PVC suppliers want PVC to replace copper. And copper suppliers think plastic plumbing is ridiculous. They are just different systems with different pros/cons. I will admit I didn't think of any of the cold weather applications due to only having plumbing experience here in florida.
Sean
Old 09-21-2013, 03:27 PM
snrusnak's Avatar
Rep:1388
Slow and steady wins the race Got a few hours in this morning...
Sean
