opinions wanted - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 05-31-2013, 05:13 AM
Ewag2983 Ewag2983 is offline
Vehicle: 05 Ram 2500
Color: Blue
Ewag2983 is on a distinguished road
Default opinions wanted
So I recently got my 05 ram 2500, atlantic blue pearl in color. The paint has some pretty deep water marks all over and is slightly oxidized and not very smooth. I tried Meguiars Ultimate Compound on a cheapie orbital polisher, but it didn't do a whole lot of good. What products could I use to bring it back to life? I can post pictures if that helps.
Old 05-31-2013, 10:17 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
After a good wash a good idea would be to clay your truck to get the atmospheric crap off, which is what makes the surface feel rough and will inhibit the proper adherence of polishes and waxes. Next to address the issues you described, you should consider a polish followed by waxing or sealant. Meguiars makes some good products, I use and like Griot's Garage, then there is Zaino, Adams to name a few. All of these make very good products, you will have to find what works best for you. You say you have a "cheapie" orbital polisher, consider getting a good high quality random orbital unit. The two I am familiar with and are excellent are Griot's Garage and Porter Cable, there are probably others and I am sure someone will chime in with other recommendations. A machine is not necessary, but well worth it for the time it saves and the less effort required.
Old 05-31-2013, 11:59 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Great info ^^
As Hermes1 said, you need to clay bar the truck first. Right now your polish isn't getting onto the surface of the paint properly because of all the other junk in the way. Once you clay bar it your paint will be fairly smooth again which is when you can start polishing.
For what you're doing the Meguairs should work great. I just used the same product (along with a few others follow it) and my paint turned out amazing. The difference is that I'm using a Porter Cable DA polisher, not a cheapie one. I'd highly recommend getting the Porter Cable. I got mine from autogeek.net. $200 for the polisher and accessories, 7 CTS pads, pad cleaner and conditioner, and a "how to" DVD. Can't beat that! They're a great site to get detailing supplies and equipment from. They also have a great youtube channel with in depth videos on how to use all their products correctly and get the best results on your truck. Check them out!!
Here's a link to my thread with some pictures of the products I used and my truck after using them if you're interested.
http://www.ramforumz.com/showthread.php?t=142829
Old 05-31-2013, 05:46 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
also the problem is not always product related, but technique related.
make sure when youre polishing, youre using some pressure and making at least 6 section passes (once up and down and once back and forth is a section pass). Clean your pads often, and it is going to take a variety of pads and step to do it properly.
maybe we can get some pics and some insight into your steps/procedures?
Old 05-31-2013, 11:03 PM
Color: Blue
So I did a meguiars clay bar before work tonight. Theres definitely a noticeable difference. Ill get some close up pics of the worst areas when I get off in the morning. Thanks everyone!
