Old 05-31-2013, 07:41 AM
trojanman22 trojanman22 is offline
Vehicle: 2010 Ram 2500 Laramie Megacab
Engine: 2010-2012 409ci (6.7L) Cummins Turbo Diesel 305hp 610lb/ft (Chassis Cab)
Rep:13
trojanman22 is on a distinguished road
Default What's needed for front LED turn signals???
I know I need two load resistors and 3157 LED's. But do I need the CAN BUS?? Non CAN BUS?? Or CK LED's??? Non CK LED's???
I'm ordering from superbrightleds
Old 05-31-2013, 08:12 AM
TsubaMaster TsubaMaster is offline
Vehicle: 2002 Dodge Ram 1500
Color: Auburn/ Crimson red
TsubaMaster is on a distinguished road
If you're ordering from super bright leds, they have CANBUS specific 3157's. that should be all you need.
Old 05-31-2013, 08:16 AM
Rep:13
Well I wanna say I tried those on my tail lights and they didnt work so I had to return them and get the load resistors. But I can't remember for sure
Old 05-31-2013, 10:20 AM
Asur Asur is offline
Vehicle: .
Rep:4371
I installed LED's on all 4 corners and on my 2012 I had to install a resistor on all 4 corners, no issues, no hyper flashes, no problems. But apparently there is a code that can be added to the system which will allow LED lights to replace the bulbs, maybe check this out
http://www.ramforumz.com/showthread.php?t=142351
Old 05-31-2013, 10:32 AM
RogerRamJet's Avatar
RogerRamJet RogerRamJet is online now
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I put the switchback style on my truck last night, with a resistor. It's been working good.
Old 06-02-2013, 05:46 AM
Rep:13
What wires did u tap into for that resistor?? And I don't know if I want the switchbacks because I don't want them SUPER BRIGHT!!! I have switchbacks in my reverse lights. I just want LED's for the DRLs. Not too bright but something better than the weak yellow. They look weird with my AAC square halos!
Old 06-03-2013, 01:25 AM
God Bless Texas!
Rep:2929
I tapped in to the ground and high or blinker wire, the wire that is hot when you use the turn signal. With the resistor in-line, it fools the flasher relay to thinking there is still a regular bulb in the socket.
Old 06-03-2013, 01:26 AM
Rep:13
Do u know wire colors???
Old 06-03-2013, 01:32 AM
God Bless Texas!
Rep:2929
I know the ground is black, as for the high and low, I don't. I took a volt meter and read which one was hot when I turned the running lights on. Process of elimination means the third is the high/blinker wire. I think I recall someone saying it was the two outside wires going in to the connector.
