older zex kit on new ram - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 05-31-2013, 07:35 PM
redlightmike redlightmike is offline
Vehicle: 2012 Ram Express RCSB
Rep:36
redlightmike is on a distinguished road
Default older zex kit on new ram
im gonna borrow an older zex kit from a friend and attemp to put it on my truck. The problem is his kit isnt for a fly by wire setup so im not sure if im going to run into any problems or not. I was hoping someone here has already done this and had some pointers.
2012 Express RCSB..2/4 belltech drop, 22s,tonneau cover, 4.10s, true duals with x and magnaflows,vararam air grabber,180 tstat, 2800 circle d, diablosport trinity....headers and ported tb(coming soon)
Old 05-31-2013, 08:12 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
what's all included in the setup you have?
Old 05-31-2013, 10:35 PM
Rep:36
Im gonna pick it up tomorrow so ill have to get back with you on that.. i know for sure it has the control box, bottle, lines, purge, bottle heater, and i bought the hemi fuel line adapter
Old 06-01-2013, 03:12 AM
chefred112's Avatar
Rep:656
if it has a control box with the solenoids then it's a wet kit which is pretty safe and easy to install on a hemi...fuel line connects where the shrader valve is on the fuel rail...do you have a wideband so you can monitor fuel trims when it activates? also, for security sake, are you running colder plugs (ngk 4306's) as well as a 180 tstat?
Old 06-01-2013, 03:17 AM
chefred112's Avatar
Rep:656
i mounted my box on the firewall..
you can see where the fuel solenoid line goes to fuel rail..
where I use to run by bottle..
where I run it now...
Old 06-01-2013, 10:52 AM
Rep:36
I do have a 180 stat but i havent changed plugs yet. Is it nessasary for only 100 shot? I looked at the plugs you listed and they say tapered seat, mine is a flat seat plug
Old 06-01-2013, 09:22 PM
Rep:3347
The 4306's fit just fine, and yes, you need a colder range for anything over a 75 shot. I was running 2 stages colder for my 150 shot with a 13.4 CR.
Old 06-28-2013, 11:23 PM
drp6982's Avatar
drp6982 drp6982 is offline
Vehicle: 2011 3500 SLT Diesel Dually
Trim Level: 3500 SLT
Rep:185
drp6982 has a spectacular aura aboutdrp6982 has a spectacular aura about
yup, 1 step cooler for a 100 shot.... I have had friends blow motors for not running the right plugs, its very important.
Im spraying anywhere from a 300 to 500 shot on my Charger and I use Brisk Plugs. They are a great plug if you plan on using nitrous more or start upping the shot some.
Also, if you are going to keep the bottle that close to you (Which Im not a fan of), I would get a pressure gauge for that bottle. I've had a bad disk on the blow off valve before and the bottle hit a certain pressure and blew up in the car..... luckily this was on the dyno but you never know
My Mopar Stable: 07 SRT8 Charger 440 Stroker with Direct Port Nitrous (1320ft - 9.18 @ 147mph)'
2014 Dodge Durango R/T Hemi
2012 Chrylser SRT8 300 Fully built 392 on 10Lbs of Boost
2011 Ram 3500 SLT Big Horn Dually
Old 07-06-2013, 01:27 AM
blue beast's Avatar
blue beast blue beast is offline
Vehicle: 2011 dodge ram
Trim Level: express
Color: blue
blue beast is on a distinguished road
im running ngk 7787 in my ram spraying a 150 shot. fixing to try a 175 tomorrow.
