Old 06-01-2013, 06:25 AM
KAZ KAZ is offline
Vehicle: 2013 big horn ram
KAZ is on a distinguished road
Default HID fog light install problems
Hey guys I'm having problems getting my hid fog light kit to work. Only one side will come on and even the one side that I do get to come on isnt very consistent. Any ideas on what the problem might be?
Old 06-01-2013, 09:56 AM
Hemiproud Hemiproud is offline
Vehicle: 2010 Ram Crew Cab Hemi
Color: Tan
Rep:23
Hemiproud is on a distinguished road
Are you using the Auto side of the headlight switch? Bc with mine I have to turn the switch to the right or sometimes it will do this. If that's not the case make sure that both ballast are humming (very faint). If not then you might have swap the wires that plug into your factory harness. Hope this helps
Old 06-02-2013, 01:47 AM
dragginbody dragginbody is offline
Vehicle: 2008 Dodge Ram 1500 5.7 Hemi
Color: Lava
dragginbody is on a distinguished road
Try swapping bulbs and see if the problem stays (ballast) or if it follows bulb.
Old 06-24-2013, 08:44 AM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
You need a canbus hid kit... Usually around 100.00 bucks... It will give you the right thing and no errors.... Get the 55w kit
