Old 06-01-2013, 12:48 PM
danstanford danstanford is offline
Vehicle: 2013 Ram
Trim Level: Laramie Long Horn
danstanford is on a distinguished road
Default Does air suspension make it underground parkable?
I am in the city a fair amount and stuck with underground parking as my only option for blocks. I am thinking that with the 6'3" lowered height, I can get into lots of garages that will not allow 6'6" standard height.
Anybody with the air suspension have this experience?
Dan
Old 06-01-2013, 06:09 PM
kamchakaa kamchakaa is offline
Vehicle: ram 2013
Trim Level: Leather black
kamchakaa is on a distinguished road
attention, after a lapse of time the vehicle returns to its standard height, does not remain at a low level.
Old 06-01-2013, 08:57 PM
mdragon9 mdragon9 is offline
Vehicle: 2013 Ram Laramie Longhorn
Trim Level: Laramie Longhorn
Rep:16
mdragon9 is on a distinguished road
Dan
Yes this is a big reason why I bought the air suspension. I use exit/exit mode daily to get into an undergrund parkade at work. Any other new 4x4 truck on the market is to tall.
Old 06-01-2013, 09:05 PM
Rep:16
What BS...you don't know what you are talking about. The truck stays in exit/entry mode until you drive faster than 24 kph or push the button to raise it. Time hasn't nothing to do with it.
Old 06-01-2013, 11:03 PM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
Dan
You will be perfectly fine. I will be in the same situation as you when my Truck arrives. As long as you do not go faster then 24Km/hr in the underground it will remain in entry/exit mode. you will also need to always remember to bring it down to entry/exit mode well before entering as it will take some time to completely lower. all the while making sure to be traveling slower then 24Km/hr
Though according to the RAM 1500 Spec guide the overall normal ride height on a 6'4 CC with 20" tires is only 77.5 inches which is just over 6'4 and is enough to fit Underground parking lots with 6'6 Clearance as I triple checked this as that is the clearance I have at my works underground in Toronto.
So it should be fine with 2" clearance without lowering it. though I will probably lower it anyways to have extra clearance and be on the safe side. specially if there any bumps or high spots in the garage.
Old 06-02-2013, 03:40 PM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
Is there not a "lock" feature to keep it locked in entry/exit?
On our Land Rovers, if you hold the button for 3 seconds, it locks the suspension in Access height, so if you're driving in a parkade and do go over the speed limit, it wont raise the vehicle.
Also, I've yet to come across a parkade or underground parking that my truck doesn't fit in. The closest I've gotten was at West Edmonton Mall, and the antenna would hit and scrape.
Old 06-02-2013, 04:07 PM
Rep:2657
I have to wonder if the Satellite Antenna height is figured into the Clearance height
Old 06-02-2013, 05:09 PM
Rep:71
It should be as it states overall height in the RAM 1500 Spec guide
Old 06-02-2013, 05:31 PM
kxlexus kxlexus is offline
Vehicle: 2013 Laramie 4X4 Quad Cab
Trim Level: Laramie Hemi 8 Speed
Color: Maximum Steel Met.
Rep:25
kxlexus is on a distinguished road
There is no lock feature
Old 06-02-2013, 05:44 PM
Rep:71
the closest would be to set it at desired height then disable it using one of the service modes such as Transport mode Though because I haven't received my Truck I can't confirm it holds that position or default to normal ride when it gets disabled.
