headlights. led - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 06-01-2013, 07:32 PM
tommypho23 tommypho23 is offline
Vehicle: 2000 dodge ram
tommypho23 is on a distinguished road
Default headlights. led
how do i wire the leds and the ring to a switch.
Old 06-01-2013, 08:03 PM
Arth's Avatar
Arth Arth is offline
Trim Level: Laramie Limited
Rep:2035
Honestly? Your best bet would be to get some quick splices and splice them into your parking lights.
That is what I did with my set of 2001 headlight like the set you have.
Connect the white and the red to the power on your turn signal wire. Then the black wire to the ground. Do that for both sides and the LED's will come on when you turn on your parking lights.
Chrome... in moderation.
Old 06-01-2013, 08:53 PM
they won't blink when i turn on the turn signal?
Old 06-01-2013, 08:56 PM
Arth's Avatar
Rep:2035
Don't wire them into the turn signal wire. Wire them into the running light wire. Your actual turn signal harness has three wires that connect to the plug that has the bulb connected to it. One wire is for the turn signal, another is the ground, and the last one is for the running light. That is the one you want.
Best way to figure which wire does what is to take a multimeter and probe the socket with your running lights on.
Old 06-01-2013, 11:21 PM
do i splice the red and white wires from both headlights into 1?
and same with the black wires. and how do i splice it to the running lights wire?
Old 06-02-2013, 02:08 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Yes, you may splice the red and white wires on to the same running light wire, same with the black wires. There are several ways to splice, however, the easiest is by using quick connects, which I took pic of below. You can find them at any auto store. Any questions, let us know.
Good luck and have fun!
