Old 06-09-2013, 09:09 PM
2010Ram1500 2010Ram1500 is offline
Vehicle: 2010
2010Ram1500 is on a distinguished road
I see. I will then take another closer look at the wiring as well.
Thanks.
Old 07-18-2013, 09:09 PM
Vehicle: 2010
Hi everyone. I finally took the plunge and got a new actuator from the dealer. It costed about $150 with taxes. I replaced the Driver side unit this time around, as its the side I use always. It was definitely the actuator unit. I will attempt the passenger side at some point.
Thanks everyone for your input.
Old 08-21-2013, 03:15 AM
aktrite28's Avatar
aktrite28 aktrite28 is offline
Vehicle: 2009 Dodge Ram 1500 SLT Hemi
Trim Level: Slt big horn
Color: Blue
aktrite28 is on a distinguished road
im having very similar issue with right side front and rear doors, my rear door has been malfunctioning for few months, front passenger door just recetly started, sometimes they open sometimes they dont, and sometimes the lock only moves 1 or 2 mm instead of popping all the way up to unlock. since i have more time then money i checked i removed all boots and looked for torn wires with no luck. So im thinking a torn wire not visble or maybe the actuator, how much does the dealer charge to diagnose? im pretty sure i can replace the part myself
Old 08-21-2013, 08:50 AM
Vehicle: 2010
I would imagine its about 1 hour and translates to about $100, depending on the dealer hourly rate,
If you are doing the disassembly of the door panel and replacement yourself, I would say just order the part. I believe it is the actuator. the symptoms and degrading operation are tell-tale signs of its failure.
Took me about 2 hrs. I had to use a support for the driver side window.
I hope it helps and good luck.
Old 08-21-2013, 10:14 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
2010 would be correct. If you've got a little bit of movement, then you can bet dollars to pesos that the actuator is losing its umph. I'd check salvage yards, ebay or Amazon for an actuator. No since in paying dealer prices.
Old 08-11-2014, 03:18 PM
10Ram2500 10Ram2500 is offline
Vehicle: 2010 Ram 2500
Color: Blue
10Ram2500 is on a distinguished road
Anybody got a quick part number for these actuators?
I've had a 2010 - 2500 for about a month, but have just starting building the tool bed and driving it more. First I noticed the R/R door was not locked when all should have been ... then a night or so ago it WAS working; and then it jammed up so that it wouldn't lock or unlock at all, even manually. Gotta get this fixed no matter what; those are the kids doors.
I'd lean towards replacing all four, but we gotta find a better way than $600! With only four, maybe five years on the truck, and 67,000 miles, it seems premature to fail to me too.
And as a safety device, it should almost be prone to recall.
Old 08-22-2014, 11:49 PM
balki420 balki420 is offline
Vehicle: 2010 Ram
Color: Inferno Red
Rep:49
balki420 is on a distinguished road
I've posted instructions with pictures on how to replace the actuator here:
http://www.ramforumz.com/showthread....89#post1471889
Took me about 45 minutes. Easy job to do. Will try to break into the failed one that I pulled out to see if it's repairable for next time instead of the $150 from the dealer to replace.
Old 01-12-2016, 01:18 AM
mitch 2728 mitch 2728 is offline
Vehicle: 2010 dodge ram 1500 crew cab
mitch 2728 is on a distinguished road
MY rear passenger door lock actuator quit working. Does anybody know if the front and rear door lock actuators are interchangeable? I cant seem to find good or reliable information for part numbers and whatnot. Any thoughts would be greatly appreciated
Old 01-12-2016, 01:20 AM
@10Ram2500 I agree. 5 years with 65,000 miles is a little premature in my book. My AC quit working soon after too?!?!?!
Old 01-30-2016, 02:39 PM
fireballs76's Avatar
fireballs76 fireballs76 is offline
Trim Level: SLT Big Horn
Color: Mineral Gray
fireballs76 is on a distinguished road
Was just going to search forums for this topic and saw this! Having the same issue on my 2010, but only on the passenger front door. I did have an issue several years ago on the drivers door where it wouldn't open when auto unlock should when pulling on inside door latch. Dealer fixed under warranty, now began having intermittent issues with passenger door a few months ago, now pretty steadily not unlocking and/or locking, seems different than my original driver door problem, nonetheless appears to be actuator problem.
ALWAYS SOMETHING!!!!!!
