Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Dodge Ram Decals
Old 06-01-2013, 11:26 PM
SilverRain SilverRain is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Color: Grey
SilverRain is on a distinguished road
Default Day Time Running Light Question
I just installed new Anzo U-Bar projector headlights on my 2012 RAM 1500. It is required by law for daytime running lights (DRL) to be on in Canada. However there are no lights on after I installed the lights. Does anyone know if DRL is not compatible with these lights and do I buy some type of module to have lights on during the day without having to put on night time lights on?
Old 06-01-2013, 11:36 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2015 GMC Sierra
Color: Bronze Alloy Metallic
Rep:2035
Do you have a picture of the headlights you installed?
I think for our friends up north use the high beams for the DRL. If that is the case do these new headlights have a separate high beam bulb?
If not then I suspect that is your problem.
Chrome... in moderation.
Old 06-01-2013, 11:41 PM
Rep:3322
What lamps did you have before the swap? Quads or duals? The reason I ask is the Anzo U-Bar is designed to run the same as the dual lamps where it uses the same H9 bulb for both high/low beam, so this may be the issue with the DRL circuit since the DRL circuit uses a low-voltage highbeam, which in the case of the single H9, is also the low beam output.
Old 06-02-2013, 08:42 PM
Color: Grey
Yes, I guess you are correct, it uses the H9 bulb for both high and low beams. I think the original stock lights were quad.
thanks for the input. I guess I will have to get it wired to either have the headlights always on or wire it so the fog lights are always on.
thanks!
Old 06-02-2013, 09:00 PM
Rep:3322
Just wire the halos to an ignition-on switch and you're legal. It's what some BMWs and Audis are doing for their DRLs, you just legally need a forward facing white or amber light operating during hours of daylight.
Old 06-04-2013, 03:39 PM
Color: Grey
Perfect, thanks for the advice.
