Old 06-02-2013, 08:03 AM
Nck's Avatar
Nck Nck is offline
Vehicle: Superb 1998 Dodge Ram
Trim Level: SLT Laramie
Rep:74
Nck will become famous soon enough
Default I'm now completely stummped.
My truck recently has a clicking noise that increases with speed. but something even worse. Whenever I'm coming out of a turn and only when coming out of a turn. If I give her to much gas, it's like a trans slip but it's not. The rpm's jump up and then something grabs and jerks the truck forward. And the truck is also shifting weird since this all started.
I though maybe it was the yoke but it wasn't, so I'm completely lost.
Old 06-03-2013, 06:22 PM
Nck's Avatar
Nck Nck is offline
Rep:74
Where are all the Ram guru's?
Old 06-03-2013, 06:30 PM
02 Ram 02 Ram is offline
Vehicle: 02 Dodge Ram/92 IROC R/T
Trim Level: SLT Quad Cab
Color: Forest Green
Rep:67
02 Ram will become famous soon enough
is it 4WD? if so it could be the CV axles. on my FWD car clicking/clunking up front is 9/10 CV axles
2002 Dodge Ram 4.7L
1992 Dodge Daytona IROC R/T 2.2 Turbo
Old 06-03-2013, 07:47 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Rep:326
The 2nd gens don't have CV axles, they're a solid front axle. I was gonna say check your axle u joints, but the jerking/rpm issue has me stumped.
Old 06-03-2013, 08:32 PM
Color: Forest Green
Rep:67
gotcha. all ive ever owned were FWD Dodges and this truck
2002 Dodge Ram 4.7L
Old 06-04-2013, 06:41 AM
Nck's Avatar
Nck Nck is offline
Rep:74
It's not in fwd when it happens. I'm gonna open up the rear diff today to see if it's chewing it self up. and also I'm going to replace the transmission shift solenoid for my erratic shifting.
Old 06-04-2013, 12:05 PM
Rep:326
It maybe 2 separate issues.
Also, your axle u joints still spin even when you're in 2wd. Mine made a clicking/binding noise when they went bad. I could move my passenger side one by hand with it still on the truck.
Old 06-04-2013, 12:10 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I didn't want to chime in, because I'm really not sure. If understand what you're saying then very first thing that comes to mind would the torque converter.
I'm pretty sure I understand the symptoms you're describing, and that's what they'd indicate to me. I've always stayed away from transmissions just as much as gynecology. I've looked into them and put my fingers in there, but they're just not something I'm comfortable opening up.
I do know that when you turn, the outside of the vehicle's wheels turn faster than the inside wheels, and that may be enough tension to cause a bad torque converter to disengage. Once straightened out the tension neutralizes and the torque converter could be engaging, causing the jerking sensation without a shift issue. The clicking may be coming from the torque converter.
Any possibility of getting the rear off the ground and putting a little pressure on the drive-train with the e-brake and putting an ear under there to pinpoint the clicking noise?
Admittedly this is merely a suggestion applying mechanical aptitude.
Old 06-04-2013, 09:13 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Tranny oil level right? Thats all I could attest to the neutral 'jump' thing, the clicking frequency thing I would attest to axle joints, IF it's 4wd... 2 pennies worth...
Old 06-05-2013, 03:30 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I cleaned out and changed the oil in the differentials, just in case. i found the clicking noise, it's just bad universal joints like you guys said. For the jerking thing, i am going to look into a bad torque converter as mentioned. I'll keep you guys posted.
