Rear Brake Lines HELP - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-16-2013, 12:47 PM
98rumblebee's Avatar
98rumblebee 98rumblebee is offline
Vehicle: 1998 Dodge Ram 1500
Color: Yellow + Black
98rumblebee is on a distinguished road
Exclamation Rear Brake Lines HELP
Hey everyone. I've desperately need help figuring out the rear brake line on my 1998 Ram 1500 5.9 4x4 reg. cab truck. The line was rotted through, and when I removed it I discovered that it was too rusty to tell what was where. There is a mounting bracket affixed to the frame which I'm replacing. Also replacing the hose and the distributor (T-block) that it connects to. But I need the parts to make the brake line from the master cylinder connect to this rubber hose when it gets back there. Different sites are showing me different parts on slightly different setups. If anyone has a truck like mine and can take a picture of this setup I'd appreciate it. Be real nice to have brakes...
Put a good dip in
Old 05-16-2013, 12:53 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The rubber hose should just have a clip that holds it to the frame bracket, and the brake line threads into the rubber hose (metal compression fitting end). The hole in the bracket should be "D" shaped to keep the rubber line in place.
Old 05-17-2013, 07:41 AM
Thanks for the info and yeah I know I gotta get one of them clips. And I'm replacing the bracket so that shouldn't be a problem either. But how does the brake line thread into that fitting on the end of the rubber hose? I don't have any brake lines with threads...?
Put a good dip in
Old 05-17-2013, 09:05 AM
Vehicle: 95
Rep:1776
I'll see if I can get a picture of mine up here.
Old 05-17-2013, 11:59 AM
Alright thanks. Actually what we're thinking now is that the brake line goes and just threads into the fitting, and the fitting kinda makes threads on the line as you go...
Put a good dip in
Old 05-17-2013, 06:32 PM
Vehicle: 95
Rep:1776
Not really. The end of the steel line is flared with a nut over it (Male).
The rubber hose has a crimped end (the "D") and is reverse flared/nipple/female.
And they screw together.
Maybe yours was just so deteriorated it's hard to see the connection.
Something like this...
But yours is rubber instead of braided steel.
Old 05-21-2013, 08:35 AM
Gotcha. It looks like I'm just gonna wing it... the factory way aint the only way
Put a good dip in
Old 05-28-2013, 12:03 PM
Alright: update time. I couldn't get the distributor block off the rear axle, so I just bolted it to the differential cover using one of the existing bolts. ran a brake line straight into the brake hose using a standard fitting, thus bypassing all the need for brackets and adaptors and crap. My problem now is that I can't bleed it since the bleeders are rusted and stripped, and now I can't get the drums off b/c they are rusted on as well... what is a good way to get these drums off, besides the ol' hammer method?
Put a good dip in
Old 06-06-2013, 06:33 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Lots of PB blaster. That stuff is great. I had to use it to get my bleeder screws out when I did my brakes. Then once I got them I replaced the bleeders and used a ton of anti seeze.
Old 06-06-2013, 06:42 PM
Vehicle: 95
Rep:1776
Try to loosen up the self adjusters through the access hole in the back. Then hit the drum between the lug nuts a couple tines with a BFH. DON'T hit the lug nuts.
