Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 07-24-2013, 04:31 PM
MartinFielding MartinFielding is offline
Vehicle: 2011 Dodge Ram 1500
Color: Green
MartinFielding is on a distinguished road
I think you are correct on the allen key size, John. The problem was - the metal within the fitting was fairly soft - and the threads on the fitting were very tight to turn. So the allen socket simply rounded out the inside. Probably would have worked if it wasn't so tight to turn. Even once I was able to get a 9/16 socket on the outside of the fitting - it took considerable force to remove it (thread dope?)
I appreciate all the help I have received from TLC and this forum (I think I might have read every thread on this topic). Love the product - and can't say enough good things about it.
Old 07-25-2013, 08:32 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Mine were rusted, a quick shot of PB blaster and they came out with a bit of force.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 07-29-2013, 09:56 PM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
I had to heat mine when I finally go mind swapped out. Finally completely leak free and fully functioning
Old 08-10-2013, 03:33 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Mine are leaking also and at the base of the quick connect, this should be something that should be checked before shipping them out, both leak the left side more than the right, I will have to pull all this apart lying on the ground in my driveway. So here is a Question, after 6 months of them being on the truck I also noticed this morning that the rubber mat that is glued to the air bag is unstuck and moving towards the front of the air bag, at this rate in a year they will fall off, is this a warranty issue, or do I now have to also check this issue so as not to loose the rubber pieces, and when I pull all this off, what do I do to glue this back to its location? if not under warranty and being under the truck I might as well fix that issue also, what should I use to glue them back so they don't come off anymore?
Here is a pic of what is going on.
Old 08-10-2013, 03:58 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Asur,
I'll forward this and have our tech people get to you.
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 08-13-2013, 11:54 AM
ArmyofOne's Avatar
US Army Retired
Rep:1195
if you deflate your bags completely, jack up the rear of the truck, you can pull that pad off. use some 3M double sided tape and stick it back on, thats what I did. I also found it works better if you stick it to the plate on the axle, rather than the airbag plate.
I want you guys to know that EVERY piece of feedback we get is used for R&D. We are taking these comments to heart and we really want you all (our customers) to be happy with the finished product. If there is anything else we can do for you, please dont hesitate to ask!
US ARMY-RETIRED
Old 08-13-2013, 01:50 PM
Vehicle: .
Rep:4373
Anybody who has issues or technical support questions please contact Lola Mullican at "lola75tlc@gmail.com". She is the Executive Director
For Customer Relations at Total Load Control and will provide information and customer service for TLC products.
Old 08-18-2013, 04:46 PM
TLC John's Avatar
Rep:17
If anyone has a problem with a leak in their TLC system, please contact Lola or me.
Total Load Control™
Old 08-29-2013, 02:17 PM
Vehicle: .
Rep:4373
Got the valve replacements last week, spent the day Saturday pulling the bags off and installing the new valves, put in the pins that where sent to me, the ones for the front side of the bags need to be shortened as they will hit the support where the plate is attached to the Axel. right now they are re-installed with the new valves, they have not leaked since Saturday. My only issue now is that the right side bag the pins do not align with the holes in the plate and the air bag is skewed a bit, does not seem to hinder the bag but its sort of crooked. as if the holes should be more towards the outside of the truck about half an inch. I checked if I could move the plate over but there is no room to do it. Will see if it will seat itself over time. Thank you for the repair parts, I am happy my pump does not go off ever 5 min. If anyone has the same issue about the pins and the bag being off please let me know, will keep this updated over the next few weeks on the leaks.
Old 08-29-2013, 11:30 PM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Did they change mount plate design again ? What do your mounts look like and what pins are you referring to ? Just curious as I read the post that the bag actually shifted and the exhaust burnt a hole in it.
