Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 09-02-2013, 09:35 AM
bendodge bendodge is online now
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Default Leak/mount change
Lola contacted me and has is sending me the parts required to fix the leaks. they are also sending me instructions and parts for a mortification to the lower mount.the way it was explained I will be drilling some a additional holes in the plate that goes on the axle and add two studs to the air bag. these are keep the bag in place on the bottom.The customer support from TLC has been excellent.
Old 09-02-2013, 02:36 PM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
It is my understanding the holes are already on the bottom plates, all you need to do is insert the studs into the airbags. Can TLC confirm this? - Thank you
Old 09-02-2013, 04:53 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
if you have any tech questions or concerns please contact Lola with Customer Care.
She can answer all your questions and concerns.
You can contact her by going to our website and hit customer service contact Lola or direct at lola75tlc@gmail.com
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
Old 09-02-2013, 06:45 PM
Asur Asur is offline
Vehicle: .
Rep:4371
for the driver side it will line up fine, but for the passenger side you will need to make 2 holes 1/2" in size (just to be sure your stud fits in nice) and at an offset of about 1/2", then when you re-install the bottom plate, you will need to aligne it up, if you loosen the bolts that hold the bag to the top part you can easily wiggle it into place, then tighten it all up you should be good to go. I did my hole setup on the passenger side today.
Old 09-04-2013, 08:39 PM
Vehicle: .
Rep:4371
OK update, no more leaks, period, the pump has not re-started since I changed the valves. New holes in passenger side plate, with studs provided by TLC, no noise, no issues, and truck rides great, still a bit of a rake but i will live with it.
Review
Service:
The people at TLC took the time and made the adjustments to make sure there product works, and they did it in a professional way.
Can you reach them for answers : yes
Are they professional : yes
did they provide help with issues on there product : yes
am I satisfied with there after sales service : yes
Product:
Still love the product, solid, nice, strong and well made.
would I recommend the product : yes, now with the new ver its excellent.
Thank you for the help with my issues, I am happy with the results.
Old 09-05-2013, 12:17 AM
Vehicle: 2012 Ram
Rep:163
Default Stud kit/ leaks
Removed airbags and mounts to install new inlet fittings in bags and add studs to bottom of bag. the template that was sent is a bit off in size to my plates. I looked the template over that they sent and marked my lower plate according to the template. The drivers side works fine but the passenger side is off a bout a half of a hole so i ended up drilling a new hole between the 2 original mount holes in the lower plate, now everything is lined up and am currently testing for leaks. I did make a plate to go over the original mount holes to strenghten that area since there are now 3 holes in the lower mount plate. I did modify my systems air lines because my trailer was swaying a little and I had never had this problem with my Dakotas with separate lines for each bag, that did the trick no more sway. Customer support has be great and the product seems well made.
Old 09-14-2013, 12:42 PM
Vehicle: .
Rep:4371
Another Update
Almost 2 weeks now and still no leaks with the new valves.
Old 10-08-2013, 06:06 PM
Vehicle: .
Rep:4371
Another update, the new valves work great, the pin setup for the bottom plates work great also. 1 month now and bags stay full, the only time the pump goes is due to temperature changes it re-adjusts the air pressure. Thank you for the parts TLC
