Old 06-02-2013, 09:55 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Default TOYO 35 12.50 20s on stock rims?
OK ..I have been looking everywhere and I must be missing something I thought I read a while back before my life got complicated again and I had to take a break from the pc.
I was sure I read that someone put Toyo AT2 Xtremes 35 12.50 20s on stock rims with bilstein 5100 adjustable height shocks at max height and they had no rubbing issues? It was on an identical truck to mine except it was black I thought. I have the 2012 Ram 1500 QC 4wd Express. With the stock tires I have 40 inches to center of fender from ground on the rear and 36 1/2 on front stock suspension.
If you know for sure this works or does not work, I could use a heads up cause I am ordering everything tomorrow. The shocks, the tires, new Y pipe, and Mufflex 18.
Sooner the better on the reply thanks much guys and gals.
OH BTW I'm BAAAAACKKKKK
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 06-02-2013, 09:57 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
the toyo open country 35's do not come in a 1250 they come in a 1350, the will fit on a 20x9 factory rim, and you will need a wheel spacer, however the recommended wheel size for that tire is a 20x10.
Thanks
Jeremiah
Old 06-02-2013, 10:03 PM
Rep:69
My Mistake the tires I have lined up are Toyo AT2 xtreme and are 35 12.50 20s. Does that help?
Ill edit my post.
Old 06-02-2013, 10:08 PM
SK-Ram SK-Ram is offline
Vehicle: 2014 Ram
Trim Level: SPORT
Rep:54
SK-Ram will become famous soon enough
As Jeremiah said, youll require a wheel spacer to prevent control arm & sway bar rub.
Old 06-02-2013, 10:13 PM
Rep:69
Will a 1/4 inch spacer work with the factory wheels? I really don't want to swing the cash for the wheels if the toyos will do the trick?
Old 06-02-2013, 10:18 PM
Rep:69
I got quoted 1367.00 that's 4 tires mounted, balanced, 50,000 warranty, road hazard out the door at Town Fair right in my home area. If there is another size tire that will give me similar fitment I am open to suggestions. I want close to 35 as possible and want the stock rim. I would rather have a narrower tire honestly than the ones I looked at but they seemed to be the best buy for the tires I looked at.
That price was with a Disabled Veteran Discount they offer. Also offer a Veterans discount too.
Old 06-02-2013, 10:21 PM
Rep:69
I gotta run 5 am comes early, the Grandson is part rooster. I will check in the am to see if I got results. Thanks much guys.
Old 06-02-2013, 10:33 PM
Vehicle: 2014 Ram
Trim Level: SPORT
Rep:54
Yes that is a perfect setup.
Old 06-02-2013, 11:03 PM
Iamahemi Iamahemi is offline
Vehicle: 2012 Ram Power Wagon
Color: PW7
Rep:58
Iamahemi will become famous soon enough
How about the toyo AT2 in a LT 295/65/20. Recommended rim is 8.5" the tires measure 35" x 11.8".
2012 PW bright white,Leer cap,Bedrug,2010 rear headrest swap,black Mopar side steps, debadged
Old 06-03-2013, 01:16 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Those should work just fine, you might still want to run a 1/4" spacer just to be safe though
Thanks
Jeremiah
