Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-03-2013, 09:18 AM
Gibson3500 Gibson3500 is offline
Vehicle: 2005 Dodge ram 3500
Gibson3500 is on a distinguished road
Default 05 3500 Overheating
So I have an 05 ram 3500 dually with the 5.9 in it. I also have the banks high rise banks intake and full exhaust. I pull a small excavator 2 or 3 times a week and really notice my overheating issue then. But then even when im not pulling anything it still creeps up past 220 then ac stops blowing cold and I have to roll down windows. I have already replaced the fan clutch the radiator the radiator cap the thermostat and the water pump along with all the hoses and I am still having the same problem. I have put all kinds of money into this problem with no prevail so any help would be greatly appreciated
Thanks
Old 06-03-2013, 11:46 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
How is your coolant level? Is the reservoir/radiator staying full? Since you've already replaced everything, my first guess would be you have a flow/circulation problem. Even though you have a new water pump, you could still have some blockage.
Old 06-06-2013, 07:38 AM
My coolant level stays fine right at the line on the res and I checked the radiator hoses with a thermal temp reader and everything is close to the same temps...ive run out of ideas everything has been replaced and my problem just wont fix itself
Old 06-06-2013, 08:36 AM
Cowboy Medic's Avatar
Cowboy Medic Cowboy Medic is offline
Vehicle: 2012 Ram 3500 Outdoorsman
Trim Level: Outdoorsman
Color: White and Mineral Gray
Rep:232
Cowboy Medic has a spectacular aura aboutCowboy Medic has a spectacular aura aboutCowboy Medic has a spectacular aura about
My '99 Diesel did this as well. The blowby tube that comes down on the front of the engine allows oil mist to get on the radiator and over the years there is a surprisingly large amount of dust and dirt that gets collected and plugs up the fins of the radiator. Way more than you would believe if you are looking at it without taking it out of the truck.
The best advise I can give you is to bite the bullet and take the radiator out of the truck and give it a very thorough cleaning. I did this and it acutally only took me about 2 hours total until it was back in the truck and getting the coolant refilled.
Good luck
Current Truck = white 2012 3500 Outdoorsman
2012 Build Thread
My old 2011 Build Thread
My first Dodge photo thread
Old 06-06-2013, 09:23 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
What type of coolants have you been using in the past? When has the coolant been changed out? Have you verified fan is turning on at operating temp? Cooling fins could be clogged up and need to be cleaned.
Are sure you purged ALL of air out of the system properly?
Old 06-18-2013, 04:27 PM
well I think I have found the problem...after changing out the radiator I guess the fan didn't get put back on right and it isn't spinning at all...the thing the fan screws on to will spin when engine gets to temp but fan wont spin im not sure if this happened recently or not because what led me to look at the fan was the fact that my truck temp started pegging into the red with in the last week...im thinking im gonna have to take it to dodge tomorrow and pay an arm and a leg
Old 06-18-2013, 08:36 PM
God Bless Texas!
Rep:2929
Sorry to hear that, Gibson. I hate going to Dodge for anything, mostly because it does cost an arm and a leg. Let us know how it turns out.
Old 06-19-2013, 01:21 AM
scrappy scrappy is offline
Vehicle: '12 ram 3500
Trim Level: laramie limited
Color: mineral grey
Rep:29
scrappy is on a distinguished road
Good luck
the '05 does not use the same system and is not suseptible to this like a second gen.
OP, the fan not turning doesn't necessarily mean anything, the fan is mechanically driven but electronically controlled. it will not engage unless commanded by the ECM. Have you looked at the wiring harness that runs from the fan hub in front of the fan to the bottom right side of the fan shroud? if that harness is damaged/not connected you will have no fan. have you checked for codes?
p0480 is a fan fault(IIRC)
Old 10-07-2013, 12:02 AM
philll48 philll48 is offline
Vehicle: 2003 dodge ram 3500
philll48 is on a distinguished road
i bought my truck off ebay
flew down to Fla. to pick it up
got a good deal
and i found out why
half way back home in Mo
started to heat up
put water in it and had to repeat about every 200 miles
took about two weeks to figure out that there is 2 small hose on a heat ex changer down by the starter
replaced them with new clamps not easy but fixed it took it through the desert 15 months ago temp over 105 no problems
i think that heat exchanger is also a trans heater for in the winter time
oil has to be over 60 degrees for it to shift properly
Old 10-07-2013, 09:27 AM
God Bless Texas!
Rep:2929
got a good deal
and i found out why
started to heat up
Voonderbar! Good find. Thanks for sharing.
