tonneaucovered.com
Old 06-03-2013, 03:27 PM
farmerman56 farmerman56 is offline
Vehicle: 1994 ram
Trim Level: lariame slt
Color: green
farmerman56 is on a distinguished road
Default need help with wheels
i have a 98 2500 xcab v10 4x4 would like to change wheels to get them back under the body more here is what i have now 35x14.50x16.5 swompers on about a 12 in wheel thay used a spacer to clear the tierod but it toke about a 3 in one. can i go to a bigger wheel an clear or just stuck with stock wheels to get them moved back under the body it looks like a big spider like it is thanks for the help
Old 06-03-2013, 03:30 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
jeez that tire is wide as hell. No wonder you have rubbing and stickin out far.
I don't know what you have to do on the older rams to fit those big tires and still have them tucked up. I have all the info in the world on fitting common sizes on 3rd and 4th gen rams. But not sure about your truck :/
good luck buddy. post some pictures!!
i'm gonna have the mods move this thread to the appropriate wheels/tire section
Old 06-03-2013, 03:31 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:275
Go with a 17x9 wheel of your choice (8x6.5 bolt patern) with about 4" backspace and get a 35 x 12.50 17 tire. It will give the same hight tire but pull everything back under. Not to mention the 17 is a much more common (and usually cheaper) size than the 16.5.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 06-03-2013, 03:32 PM
Rep:1900
I was assuming he was staying with his current tires
Old 06-03-2013, 03:35 PM
Rep:275
If he is running a 14.50" wide tire on a 12" wide wheel I am not sure thats possible. It may be, but I would littereally have to get underneath his rig and start taking measurments. Either way I doubt there is any way to pull that tire farther under the fender without increasing the amount of rub.
Old 06-03-2013, 03:37 PM
Rep:1900
that's what I'm sayin. I think he's screwed with that set up. gonna take a whole new combo to get the look he wants I think
Old 06-03-2013, 03:39 PM
Rep:275
I agree, and I think he can do it actually pretty inexpensively. I have seen some nice wheel and tire combos going for sub $2k recently.
Old 06-03-2013, 03:41 PM
Rep:1900
Oh definitely. Stick with a 17" wheel (or maybe smaller cuz he's a 2nd gen) and some decent tires.
I got my set up shipped for $1700. definitely possible!
Old 06-06-2013, 08:16 PM
Vehicle: 1994 ram
Color: green
ok hope you can see the problem with wheels here. even my roters are out behind the wheels.
