tonneaucovered.com
Old 06-04-2013, 12:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Even more surprising that it's staying in 4th gear with 3.92's.... 6000lb is a heavy load but on flat land at 70 you should be in 5th. I even took tow/haul off part of the time on long flat straights when I towed the 4000 lbs with my 4.7L with 3.55s at 70mph. Granted I have it tuned so shift schedules and all that are not stock, but still. It did go in to 6th gear on those long flats and was fine. Any incline at all and it'd downshift to 4th for a second then upshift to 5th. Steep hills once we got in to the mountains I spent a lot of time in 2nd, 3rd, and 4th. Crawling up the mountains certainly was fun with a trailer on twisty roads where the lane isn't as wide as the truck lol.
Sean
Old 06-04-2013, 01:12 PM
ryan69 ryan69 is offline
Vehicle: 2011 ram 1500
Color: silver
ryan69 is on a distinguished road
I have the Bully Dog and I know it doesn't have a towing tune. Just stock, regular and premium. I'm not sure if the Trinity has a towing tune or not....
I know you definitely don't want to tow on a performance tune. The performance tune advances the timing too much which will give you horrible knocking when towing a significant amount of weight.
That's What I was scared of...I wonder if i should take it into dodge and get everything checked out.
Old 06-04-2013, 01:19 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
First off, how much does your 5th wheel weigh? RV makers are notorious for listing their trailer weights low, by the time you load it up, get water on board and gear, it may weight quit a bit more. Also, it probably catches quit a bit of air. As far as what gear it should be in, I'm not sure. I don't know how the tow haul button works on your year truck. On my truck, it locks out overdrive.
Old 06-04-2013, 01:25 PM
snrusnak's Avatar
Rep:1385
T/H locks out 6th gear(the second overdrive), utilizes the 3rd gear in upshifts, and extends shift points and increases engine braking.
Sean
Old 06-04-2013, 07:59 PM
Color: silver
the manufacture lists my trailer at 6270lbs I would say that I'd never come close to having 1000lbs of crap.
Old 06-04-2013, 09:57 PM
bonehead bonehead is offline
Vehicle: 2011 Ram 1500 Quad 4x4
Rep:24
bonehead is on a distinguished road
Originally Posted by ryan69 View Post
So what can I do to get optimum gas mileage while towing?
I think I want to get a bully dog or trinity tuner.
Just cant decide witch tuner will best suite my needs. Does either have a towing tune? or does everyone just use the performance tune for towing?
Does anyone else out there pull 6000lbs with there half tons? Or am I the only one that dosent want to spend a pile more and get a diesel?
I pull a 7000Ibs (Empty) travel trailer pull behind. I have the 1500 4x4 hemi crew cab with 3.55 gears and mine only goes above 3k RPM up hills. Otherwise it cruises in the low 2k Range. But I do only get 8MPG towing it.
Old 06-05-2013, 07:22 AM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
I thought the 6 speed transmissions did not come out till the 2012 model year.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 06-05-2013, 08:11 AM
snrusnak's Avatar
Rep:1385
The "6 speed" 65rfe is essentially identical to the previous "5 speed" 545rfe transmission.
Sean
Old 06-05-2013, 12:58 PM
Color: silver
I called the dealer and they said that there is a tranny update for it. they said it will make a world of difference, i guess ill try that.
Old 06-05-2013, 01:28 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
Not true; I tow on a 87 performance tune, and simply run 89 octane while towing. I've even towed on 93 performance tune with no knocking.
