Water pump going out at 50k - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-04-2013, 11:53 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default Water pump going out at 50k
My water pump went out at 50k miles it's replaced and runnin good with a delco brand from autozone. Ill upload some pictures here in a bit.
Barring on the shaft must have gone out, the pulley wobbled like crazy, coolant was EVERYWHERE
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 06-04-2013, 12:15 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I'm interested in pics, for if I ever have to do it. I have 75k miles no issues here (knock on wood).
Sean
Old 06-04-2013, 02:12 PM
Inferno10's Avatar
Inferno10 Inferno10 is offline
Vehicle: 2010 Ram 1500 Sport
Color: Inferno Red
Rep:12
Inferno10 is on a distinguished road
It wasnt covered under the powertrain warranty?
2010 Ram 1500 Sport QC, Spec-D Grille, DG Bull Bar, 23" LED Light Bar, Flowmaster Super 40, Zone 6"/5" Lift, Bilstein 5100s 2.8" front, Zone Nitros Rear, 20x12 KMC XD Riots -44 offset, 35x12.50R20 Nitto Trail Grapplers, 1100W Kenwood/Rockford Fosgate Sound System
Old 06-04-2013, 06:11 PM
Color: Gloss Black
Rep:141
my warrenty went out at like 35k i believe... and also i have a nitrous setup so i dont think id be covered lol
Old 06-04-2013, 06:15 PM
Color: Gloss Black
Rep:141
here are some pics, the removal of the water pump was fairly easy. One pulley had to be removed to allow you to remove 2 bolts from the water pump. the other bolts are all accessible. I removed my fan shroud and had plenty of room. the water pump came with the gasket.
Old 06-04-2013, 06:17 PM
Color: Gloss Black
Rep:141
duralast was the brand of the pump, i dont know why i said delco lol
Old 06-04-2013, 07:40 PM
snrusnak's Avatar
Rep:1388
So what the idler pulley needs removed? How'd you keep it from spinning while loosening the bolt?
Sean
Old 06-04-2013, 08:36 PM
Color: Gloss Black
Rep:141
The pulley is on a sealed barring, so you just remove the bolt with ease and the pulley comes right off
Old 10-06-2015, 07:04 PM
phquick phquick is offline
Vehicle: 2010 Dodge 4x4
phquick is on a distinguished road
Just had to replace mine on a 4.7 went with the Duralast as well. Thanks for the write up
2010 with 46,000 miles.
