2013 4x4 with 4.56 gears - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-04-2013, 08:41 PM
hungovr25's Avatar
hungovr25 hungovr25 is offline
Vehicle: 2013 CC ram sport
Trim Level: sport
hungovr25 is on a distinguished road
Default 2013 4x4 with 4.56 gears
the install is finished the front diff was finished today we did the rear about 2 weeks ago . i am now a 2013 4x4 with 4.56 gears
Old 06-04-2013, 09:59 PM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
Cool! What size tires are you running?
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 06-04-2013, 10:28 PM
hungovr25's Avatar
Trim Level: sport
i still have the stock 20" rims..i might put on my stock 20's from my '07 with the Mt toyo but they are a 10 ply and very heavy. i am def going to go with an aftermarket lighter rim just haven't really looked at whats out there yet.
Old 06-04-2013, 11:32 PM
Rep:75
So, stock tire size too? If so, I am very interested in knowing how it drives! What ratio did you have before? I have 3.55 and am thinking about swapping. I was thinking about going to a 4.10 or 4.56. I am also 4x4. How is it in town? Highway? Most of all, was it worth it?
Old 06-05-2013, 06:02 AM
hungovr25's Avatar
Trim Level: sport
i had the 3.55 and no LSD . i had the LSD installed and the 4.56 gears cruising around 60-65 rpm were still low even around 75 mph my rpm's were not that high made me think we could have done 4.88's .but my gas mileage went up . i also had the 4.56 gears installed on my 07 qc laramie 4x4 that truck was a beast. in that truck i was getting 19 miles to the gallon with the mds shutoff .
Old 06-05-2013, 08:09 AM
Rep:75
Thanks for the info! Very helpful. I've been thinking hard about just going with 4.56 as by calculation the rpm's still wouldn't be crazy high. I guess if its revving too high, you can always put bigger tires on. What LSD did you go with? I was leaning toward a Detroit Tru Trac, as I also just have an open 3.55. Do you have anything else done to your truck? What gears did you use? Noisy at all? I'm just trying to compare, sorry for all the questions...Thanks.
Old 06-05-2013, 08:11 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
how much did it run you to get 4.56s in your 07? I'm strongly considering the swap. These 35" mud tires are dogs
Old 06-05-2013, 10:45 AM
Bighouseonstilts Bighouseonstilts is offline
Color: Mineral Gray
Bighouseonstilts is on a distinguished road
If you don't mind me asking how much did the swap cost you? Did you use a 2011 front diff? I am having a hard time finding someone to do the work.
Old 06-06-2013, 08:58 AM
hungovr25's Avatar
Trim Level: sport
I don't remember what it cost but i ordered everything from Moes-performance . the only thing you have to watch out is the rear pumpkin the 4.56 gears hit inside the pumpkin you just have to shave the inside of the pumpkin a little
Old 06-06-2013, 09:04 AM
hungovr25's Avatar
Trim Level: sport
i think it was about 2800 .. you need a front diff from 2010 or lower. but i also had to get the LSD since i didnt have an lsd in my rear. i will try to get what was needed and done.
