Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 06-06-2013, 09:14 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Originally Posted by hungovr25 View Post
I don't remember what it cost but i ordered everything from Moes-performance . the only thing you have to watch out is the rear pumpkin the 4.56 gears hit inside the pumpkin you just have to shave the inside of the pumpkin a little
cool, thanks man!
Old 06-06-2013, 10:40 AM
Bighouseonstilts Bighouseonstilts is offline
Color: Mineral Gray
Bighouseonstilts is on a distinguished road
No regrets on going that low? I was thinking about 4.10 on the stock 20's but you are making me want to go 4.56 again.
Old 06-06-2013, 10:57 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Do you have a 6spd or 8 spd trans? If you have an 8 speed with 4.56 and stock diameter tires, that truck must fly off the line!
Sean
Old 06-06-2013, 11:21 AM
hungovr25's Avatar
hungovr25 hungovr25 is offline
Vehicle: 2013 CC ram sport
Trim Level: sport
hungovr25 is on a distinguished road
no regrets even with my 07 and all the mods with the mds shutoff i was getting 19 miles to the gallon with the 10 ply toyo's on and that was driving at 75-80 mph on the trip to Ohio .
i have the 6 speed trans
Old 06-06-2013, 01:41 PM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
Can you just confirm that you are running the stock tires right now? I know you said stock 20" wheels, but are the tires still stock size? Thanks.
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 06-06-2013, 03:36 PM
hungovr25's Avatar
Trim Level: sport
yes they are still the stock tires.
Old 06-09-2013, 10:02 AM
Supershafts Supershafts is offline
Vehicle: 2008 DR 2500
Supershafts is on a distinguished road
how much did it run you to get 4.56s in your 07? I'm strongly considering the swap. These 35" mud tires are dogs
Your truck is pretty straight forward for a regear, you just need the 4.56's for the both diffs and price wise with new gears, bearings and labor you should be looking around the 1300 to 1400.
You should run into the same issue with the tips of the ring encountering 2 spots in the housing, 1. most shops doing diffs arent a machine shop like myself and won't be able to machine the ring, 2. you can clearance the housing in those 2 spots which will be cheaper with a grinder, or the shop can do it.
I'd rather clearance the housing than listen to the machining of the ring
Originally Posted by Bighouseonstilts View Post
If you don't mind me asking how much did the swap cost you? Did you use a 2011 front diff? I am having a hard time finding someone to do the work.
The cost is all dependent where you find the front diff and all it's brackets.
You can use a 2003 to 2010 and it's brackets MUST also be taken with the front diff.
The 2013 axles work with the 03 to 10 front diff.
You will need to visit a machine shop to machine the end yoke of the 2013's end yoke it needs it's thru hole dimension machined and the ground hub dimension machined or you'll be in need of a new front shaft also.
The rear diff needs everything changed, aftermarket axles and carrier, then it's business as usual, rather than machine the carrier to get the 4.56 to work in there, which doing it that way changing everything opens you up to more choices of carriers.
