Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-02-2013, 05:48 PM
tannor p tannor p is offline
Vehicle: 1999 dodge ram 1500
Trim Level: none
tannor p is on a distinguished road
Default cylinder #3 misfireing!
i have a dodge ram 1500 and its running terrible the #3 cylinder is misfireing i have done an intire tune up including plugs, wires, coil, distrabution cap and insides, replaced intake cabarator valve, added heat incase water was in tank and also sea foam. the cylinder has good comprestion at 150, do not know what else to do!? the only time it runs OK is when i mash on the gas and then itll even bogg down i have to pump it then go. if i let off the gas it will bog down and it also does it in park and drive while not moveing. it will itle ok for about 5 mins in park then the rpms go below 500 and it will barrly chugg along. cant figure out why the cylinder is mistireing... please help if you may know anything. it is the 5.9l and i have owned it for about 8 months ran well until recently and only has 84k miles
Old 06-03-2013, 08:12 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
It would be a sticking injector, try taking the injector and switching it with the one right of it. Check to see if you get a #5 misfire. If so then replace that injector.
