Old 06-05-2013, 05:43 AM
BIALORUCKI BIALORUCKI is offline
Vehicle: 1998 Ram 1500 5.2L
Color: gray
BIALORUCKI is on a distinguished road
Default Rebuilt front differential and tranny rebuilt. Loud clunking front end
Just had tranny rebuilt and front differential rebuilt (rotors bearings housing components...) Steering components appear fine as well as u joints. I get a load clunking noise coming from the front end when rapidly accelerating from a stop. Noise goes away once I speed up, 35 or greater. If I accelerate slowly noise not so prevalent. Any suggestions would be greatly appreciated. Out of money energy and time. Thank you guys for all you do your absolutely heaven sent. Happens in all drives 4wheel high low overdrive on or off. Greater noise if turning while accelerating
Old 06-05-2013, 08:56 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Recheck the shock mount bolts at the bottom. I can't remember from the manual but the torque on them is like 100 ft-lbs.
Might also check the track bar on both the axle and frame side. Can do this with 2 people. In park, you under the front end and partner slowly turning lock to lock. Watch the ends of the track bar and maybe the sound will show itself.
There is a start on checks and to eliminate other causes before more suggestions.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
