rear end ratio - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 06-05-2013, 07:03 PM
trojjan trojjan is offline
Vehicle: 2012 Ram 2500 Longhorn
Trim Level: Long Horn and RT
Engine: 2011-2012 409ci (6.7L) Cummins Turbo Diesel 350hp 800lb/ft
trojjan is on a distinguished road
Cool rear end ratio
I have a 2012 Ram with 4:10 rear ratio. DOes anyone know where i can get a 3:21 or 3:55 ring and pinion. Would sway rear ends
thanks you
Old 06-05-2013, 07:08 PM
Turbo-Bug-9.40ET's Avatar
Turbo-Bug-9.40ET Turbo-Bug-9.40ET is offline
Vehicle: 2015 White Quad Cab
Rep:12
Turbo-Bug-9.40ET is on a distinguished road
Is your 2012 a 1500 or 2500-3500? If it's a 1500 I'll swap my 3.55 rear for your 4.10. Mine has 12k miles
Old 06-05-2013, 07:09 PM
Rep:12
What part of Florida are you in ?
Old 06-05-2013, 07:48 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
thanks you
The only way I know of to have 4.10 gears in a 2012 1500 is if it is an R/T. Otherwise, it has to be a 2500 or larger truck.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 06-05-2013, 10:12 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Yep, I'll swap with ya in a heartbeat too. You are not going to see a huge increase in mpg's if that is what you are after. The guys with 4.10's and 3.92's are getting better city mpg's than us with the 3.55's in most cases. Running 85mph on the interstate is a different story though. if you drive 75mph or less, the swap would not be worth it imo.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 06-07-2013, 07:47 PM
MrPiper's Avatar
MrPiper MrPiper is offline
Vehicle: 2012 Ram 1500 Bighorn
Trim Level: 1500 Bighorn
Rep:54
MrPiper will become famous soon enough
Agreed,
My 1500 Bighorn Crew Cab Hemi Positrac with 3.92 gear gets about 19.5 Hwy and about 17 around town. I also get about 11.5 towing in winter and about 9.9 towing in summer with air on and that's towing a 7K lb. trailer.
The only time I have seen significant mileage decrease is on the interstate cruising at speeds above 70mph. Even then, it's minimal decrease in mileage. I couldn't imagine why anyone would want to swap out for a lower gear.
Old 06-08-2013, 01:07 PM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
thanks you
First downgrade request I have seen here, usually most are begging for the higher gears you have. Why the request? You may regret it!!
Originally Posted by MrPiper View Post
Agreed,
Wow, Only a 2.5 MPG difference between city and highway
18-19 Highway and 14 city with my 2012 and 3.92. If I am a really good boy with the throttle and on a nice long flat stretch I get close to 22 MPG.
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
Old 06-08-2013, 03:52 PM
scrappy scrappy is offline
Vehicle: '12 ram 3500
Trim Level: laramie limited
Color: mineral grey
Rep:29
scrappy is on a distinguished road
I refused MULTIPLE trucks without 4.10's! IMHO if you ever want to tow fairly heavy and/or run bigger tires, 4.10's are MANDATORY!
I am getting better mileage out of my one ton dually than I was out of my 3/4 ton shortbed! the dually has 4.10's with stock tires(for now) and the 3/4 ton had 3.73's with 37's and the dually probably outweighs the 3/4 ton by ~500#. right now my dually is in 6th by 60mph (gonna put bigger tires on it to raise that a little) but my 3/4T wasn't good for 6th until 70+, even then, it was turning just BARELY 1500 rpms!
Old 06-09-2013, 10:30 AM
ChopYadown ChopYadown is offline
Vehicle: 2012 1500 st
Color: Taquila sunrise
ChopYadown is on a distinguished road
So a 4.10 yields better city mpg than a lower ratio?
Old 06-09-2013, 11:08 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Correct. Less throttle to get rolling. But you lose some hwy since you cruise at a higher rpm but it would be easier to stay in mds longer so it may offset that. I would think I wouldn't change much hwy unless you speed a lot. Am I correct guys??
12 Flame Red RCSB Express- Sold 3/2015
17 Blue Streak R/T Ordered 5/23/2017
Delivered 6/22/17
