Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Place your Ad Here!
Old 06-05-2013, 10:28 PM
zeta zeta is offline
Vehicle: 2013 Laramie
zeta is on a distinguished road
Default how to change to PSI
Does anyone know how to change the dash readout on a Laramie to PSI for the tire pressure? Mine currently reads in kpa I believe.
Old 06-05-2013, 10:34 PM
nikeman nikeman is offline
Rep:91
Do you see miles or kilometers? I think there's a setting that changes everything from standard American to foreign. Go through the evic menu and see what it's set on.
Old 06-05-2013, 11:32 PM
J Roc's Avatar
J Roc J Roc is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Rep:29
J Roc is on a distinguished road
You have to change it in the settings menu on the 8.4
Old 06-06-2013, 12:22 AM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
I'm the same way. I find it incredibly annoying. Obviously being in Canada, I have my settings set to metric, for km and celcius. But that also sets the tire pressure and oil pressures to KPa, which I don't like. Unfortunately, it's either all metric or all imperial, no picking and choosing.
Old 06-09-2013, 08:48 PM
LaramieNL's Avatar
LaramieNL LaramieNL is offline
Vehicle: 2013 Ram Laramie Crew Cab
Trim Level: Laramie Crew Cab
Color: Steel Metallic
LaramieNL is on a distinguished road
I agree, this is very annoying for us Canadians. It should be the same as the speedo where you can select between mph & kph right there on the evic. Maybe the Uconnect gurus can include this in one of their updates...
Old 06-10-2013, 12:02 AM
Keithgyl Keithgyl is offline
Vehicle: 2013 ram hemi sport
Keithgyl is on a distinguished road
You can change speedo to metric and everything else to imperial. Change evic to show speed and change to km can be done there.
Old 06-10-2013, 12:27 AM
Rep:26
Yes. But then your temperatures will be in Fahrenheit and your trips and fuel mileage will be in miles and gallons.
