Old 06-08-2013, 06:37 PM
brad.a brad.a is offline
Vehicle: 2010 dodge ram 1500
Color: blue
brad.a is on a distinguished road
Default 1-1/4 wheel spacer not seating with rim
hey im new to this site. hoping im asking this question in the right spot. I bought 1-1/4 wheel spacers i went to put them on truck and the thread size is smaller on the spacer then the truck, is that an issue? also it looks like my stock lugs are hit the back of my rim when i put spacer on so rim is not seating properly against the spacer, has this happened to anyone or can someone help me out the issue? thanks.
Old 06-09-2013, 08:45 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Welcome to the forumz. Yes, this is the correct section to post this in but it probably would have been best to start your own new thread with your question. Probably get you more responses that way. Anyway, so I think I understand the second part. Sounds like the spacer isn't thick enough to overcome the length of the stock lug studs and they are hitting the back of the rim before it can seat? That correct? if you can't turn or adjust the rim so that it will seat completely without the stock lug studs hitting, I would NOT run those spacers. The only options I see are to replace all your studs with shorter studs (which is going to be a PITA, potentially unsafe, and I don't know if they even make shorter studs) or swap to thicker spacers. Maybe a 1-1/2" would clear them? Just FYI though, everyone's opinion is different but I am not a fan of running spacers that big.
I'm a little confused about the first part. Are you saying that the studs on the spacers are shorter than the ones on the truck? If so, that could be a big deal. It depends how much shorter. You need enough lug to properly engage and torque the lug nuts. If they are any more than 1/4" shorter than the stock studs, I would not risk it. Sounds like it isn't going to matter with these spacers anyway though because of your other problem.
Old 06-10-2013, 09:12 PM
Color: blue
hey thanks for the respond i put the spacers up for sale because alot of people on here were saying a 35 tire will fit with a 1/4 inch adapter. its more temporary but i might hold off and look for new rims. and the spacers lug nuts are smaller in diameter im not sure the exact size but the lug nuts on my truck will just slide off the lugs on the spacer and the lugs for the spacer are to small to thread on the trucks studs. im not a fan of spacers eaither so i might just hold off and look for new rims.
Old 06-10-2013, 10:54 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
I had a custom set of spacers made for my 2013 Ram that are hub and wheel centric and as close to 1/4" as they could get. It's 3/8" I'd say. Cost about $200.
I would advise against the cheapo generic 1/4" spacers...I had BAD vibration in my 07 Ram with these. Had a custom set of 1/4" made hub centric only and ran these for over 5 years and 75,000 miles without an issue.
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 06-11-2013, 11:29 AM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
you should be fine with just a 1/4" spacer. it'll bring your wheels out....1/4"
or invest in some wheels with the offset you want
He did invest in Fuel wheels but why he didn't get a set with a negative offset is the question. Had he done that then spacers wouldn't be needed.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff coverhttp://i29.photobucket.com/albums/c2...pstcriuhl7.jpg
Old 06-11-2013, 11:34 AM
nfd538's Avatar
Rep:16
Originally Posted by dmac101 View Post
Doesn't anyone know what some good brand to get
Are
Motorsport-tech.com probably best spacers you can get.
Old 06-13-2013, 04:38 PM
dmac101 dmac101 is offline
Vehicle: 2012 dodge ram
Trim Level: laramie
Rep:39
dmac101 is on a distinguished road
i didnt go with a negative offset because it is all gravel here so whenthey stick past the wheel well it will chip the truck like crazy. so their is no happy medium between +1 and _12 and -12 is jst to much + 1 to little so thats why want a little wheel spacer to get mor of the look i want without throwing stones
Old 09-06-2013, 02:31 PM
blackram blackram is offline
Vehicle: 2009 Ram 1500
Rep:12
blackram is on a distinguished road
I had the same problem. I went with the +01 Fuel Nutz wheels. I then put on the CST 4" spindles and it pushed the front wheel WAY out ( like 1.5"). I now need to get some 1.5" Bolt on spacers for the rear to match them up. Best bet... Get Bushwacker Pocket Style Flares! Problem SOLVED!!!
Just need to free up another $400 to get them
09CC4x2 CST 4+1 Front, 20x9 Fuel Nutz 295/60 Grapps, Black Heads+Tails, CAI, Predator, Custom Exhst
