Old 06-06-2013, 05:22 AM
shockey80 shockey80 is offline
Vehicle: 2003 dodge 1500 4x4
Trim Level: justinshockey@hotmai
Color: justinshockey@hotmail.com
shockey80 is on a distinguished road
Default What to do next with my hemi?
I have a 2003 dodge 1500 4x4 with the hemi. I bought the truck from an old man that never used it but for hauling a boat so it has low miles. Since I bought it I have added a set of long tube mopar headers into straight pipe exhaust out the back(sounds awesome),a cold air intake, throttle body spacer, and super chips programer. It runs good but I am wanting a little more out of it. Does anyone have any input on what I should add next? I don't really want to spend the money on a supercharger but would like some input. Thanks
Old 06-06-2013, 09:42 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
remove the tbs imo.
Old 06-06-2013, 10:07 AM
bouf0010's Avatar
bouf0010 bouf0010 is offline
Vehicle: 2013 Dodge Ram 1500
bouf0010 is on a distinguished road
Originally Posted by TheSatinPumpkin View Post
remove the tbs imo.
+1
and add a ported throttle body
T-1000 HF 93 Tuned - S&B CAI w/custom air scoop - Moe's 87mm tb - Silver Ceramic JBA Shorties - Magnaflow Y-pipe - GT Custom 22" muffler - V6 E-fan mod - 180 t-stat - Catch Can - bielstein shocks - 2" rear drop coils - Cooper Zeon LTZ 305/55R20
Old 06-06-2013, 05:08 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
install a 180 tstat, e-fan, might want to do a straight thru muffler and get some low end performance back... after this then the modding get's a little more expensive (cam, heads, stall tq verter, gears...)
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 06-06-2013, 06:46 PM
What will a 180 thermostat do? And I don't really want to break into my motor untill I have to. I don't want to do gears either because I want to keep my gas mileage as much as possible.
Old 06-06-2013, 07:04 PM
chefred112's Avatar
Rep:656
a cooler running motor is a stronger running motor....you'll notice in the winter time the hemi run's stronger as oppose to the heat of summer...plus, it's also for security sake and an important component as you mod up (helps prevent knocking/detonation)
Old 06-06-2013, 07:13 PM
HemiLonestar's Avatar
Rep:261
It's a trade off, you want more performance your mileage goes down. Your tuning options are a bit limited (sucks for us 03's). Pull the spacer first. Throw it away. Use it on your desk. If you don't want to get into the engine or change gears, then biggest bang for buck is probably nitrous.
"Big Red"
2006 Charger R/T
Old 06-06-2013, 07:16 PM
chefred112's Avatar
Rep:656
this is what the spacer is good for...
Old 06-06-2013, 07:18 PM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
180 stat helps prevent knocking?
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
Old 06-06-2013, 07:25 PM
chefred112's Avatar
Rep:656
knocking is a form of lean condition or low octane fuel...to offset it, you try to add more fuel, a colder motor uses more fuel. I've never complained of knocking since I started using a colder tstat...and as modded as I am that is one thing I don't need or want to worry about..
