Old 06-06-2013, 09:27 AM
Myrk Myrk is offline
Vehicle: 2013 Dodge Ram
Myrk is on a distinguished road
Default UConnect 8.4A - Music played from SD Card/USB skips every 20 seconds
I'm about to take my 2013 1500 to the dealer to address a few common issues I'm having with the 8.4A (outside temp is off, compass is way off, clock can't keep time) and will mention this issue as well. I've searched the forums and seen a couple references to this symptom but I'm curious how widespread it is and whether any fix or TSB has been found.
Problem: Music skips every 20 seconds when streaming music from either an iPod Classic connected via USB or a 32GB SD card inserted in SD slot. It's not constant (of course, which will make it almost impossible for dealer to recreate) but once it starts it skips every 20 seconds like clockwork until the truck is turned off and the radio powers down.
I installed the 13.15.4 SW update last week but all my problems persist.
I'm pleased with most everything else about the truck but these UConnect issues are particularly frustrating because the radio is something you constantly interact with. And because someone made the (bone-headed) decision to run tons of non-radio functionality through the unit (like the HVAC soft-button controls) aftermarket options will be limited.
I've seen mentions of TSBs that should resolve the temp and compass issues. I'm hopeful there's something for the clock. Does anyone have any insight on the music skipping issue?
Old 06-13-2013, 10:35 PM
F/U for anyone interested -
I took my truck in on Tuesday and reported 4 issues with UConnect 8.4A:
- Outside temp display is off/slow to update
- Compass is off ~50% of the time
- Clock loses time, ~1 min for every 15-20 mins of drive time
- SDCard/USB music intermittently skips every 20 seconds as described above
Dealer called today and advised all problems are related to radio and they have ordered a replacement. He stated "sometimes it takes 5 days, sometimes it takes 10 days" to get the replacement, but I've read enough on here to know these things are back-ordered. I have no problem waiting if the replacement is a permanent fix.
I picked up the truck this afternoon and they advised they'll call when the new radio arrives to schedule the install. When I got home I noticed on the receipt that they applied 2 RRTs to fix the outside temp and compass. I've seen these posted elsewhere but for those that haven't seen them:
RRT 13-023 - addresses outside temp issue
RRT 13-037 - addresses compass issue
I didn't see that these updates were applied before I drove home. I'll pay more attention over the next few days to verify those issues are resolved. Hopefully the replacement radio won't have those problems at all...
Old 06-13-2013, 10:38 PM
Whitey--62 Whitey--62 is offline
Vehicle: 2014 Ram 1500 CC Rambox
Trim Level: Sport 8-speed
Whitey--62 is on a distinguished road
I'm having similar issues with mine as well. For me when I insert an SD card or plug in my phone through usb it knows something is there but will not play it at all. I'll be consulting the dealership as when I hook either up to a laptop as is well. I had an issue initially that any function in media would skip constantly. But that has stopped.
Old 06-29-2013, 02:51 PM
Update - the radio was replaced last Friday (6/21) and to date I've experienced no issues. The truck knows the temperature and which direction it's heading (fixed via updates separate from the radio replacement), the clock keeps time, and no more music skip every 20 seconds.
The new one came with 13.19.0 so not sure whether the clock and skipping music issues were related to hardware or software - but since I'd gone through several updates on the previous radio I'm guessing they were both hardware-related.
So far, so good!
