United Radio
Old 06-06-2013, 11:20 AM
mudrunnr mudrunnr is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: TRX 4
mudrunnr is on a distinguished road
Default Turn signal trouble
I recently noticed an issue with my ram. As I pulled up to the gas station, I saw in the reflection that my front turn signal lamp was on.I placed the truck in park and released the brake and the turn signal lamp went out. The left turn signals illuminate normally. I checked all the bulbs and replaced the ones I found burned out out. It still does it and now I have another issue. With the headlights off, and the left turn signal ON, the right side turn signals flash dimly. It does not do it with the headlights on. It is only when the lights are off and left turn signal on. I also checked the grounds under the hood. I am seriously confused at this point.
Last edited by mudrunnr; 06-06-2013 at 11:22 AM. Reason: Added additional information
Old 06-06-2013, 11:48 AM
SI Integra SI Integra is offline
Vehicle: 03 Ram
Trim Level: SLT Sport
SI Integra is on a distinguished road
I had a similar issue and it turned out to be a short on the board in the passenger tail light. A hairline crack allowed water in to create a short in my wiring. It was clearly visible once I removed the tail light and inspected the board. I missed it when I checked the bulbs, i went back and inspected the board after advice from a friend.
Hope this might offer some help..
Old 06-06-2013, 01:04 PM
Trim Level: TRX 4
Thank for the info. I will look at it again tonight after work. I was also thinking t could be the multifunction switch but not sure since it does it only when the left signal is on and not when the headlights are on. It was just a thought. I read somewhere about a TIPM that was causing a similar issue. Any thoughts on that?
