Got my new RAM. Also towing question. - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 06-09-2013, 12:12 AM
madhatr02's Avatar
madhatr02 madhatr02 is offline
Vehicle: 2016 Ram Rebel 4x4
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
Make sure you are checking the right information. Several people have told you to check your payload capacity of the truck. Payload capacity and tow rating are 2 completely different things.
The payload is what can be carried IN the truck NOT what can be pulled behind it. The rear coils have less capacity as to the weight they can directly support on top of them. Pulling a load that weight is supported by the trailer axles.
Every truck is different so check several different sources. Hemi with 3:92 depending on what cab you have, box length etc "tends" to be around 9K towing capacity but can be upwards of 10K.
There is a lot of BAD information in this thread FYI.
Semper Fi,
Kevin
2016 Dodge Rebel
aka Project Black Sheep
Old 06-09-2013, 12:18 AM
madhatr02's Avatar
Rep:145
Originally Posted by c4s View Post
Yep, like Explorer Rob says, check out the payload capacity sticker inside your door jamb. 99% of the time payload capacity is the limiting factor when trying to figure out what you can tow in the real world. Yours being an Outdoorsman is probably not too bad. 1300lbs maybe? Not sure. In any case, work the numbers backwards from payload and more than likely all the other values (GCWR, GVWR etc) will all be well under the max.
Don't know c4s but this is an example of what I mean you guys are talking about GVWR that has to do with the truck itself NOT towing. My Ram has max payload of 985lbs, it's tow rating is 9600.
Don't think people would be buying 50K pickups if they could only tow 1300lbs.
Semper Fi,
Kevin
2016 Dodge Rebel
Old 06-09-2013, 04:05 AM
pitch1 pitch1 is offline
pitch1 is on a distinguished road
I tow a 24 ft tt with my 2013 1500 QC Express. My trailer is 5000# fully loaded. Tow rating 8700# Cargo capacity is any thing on or in the truck other than full fluids and a 150# DRIVER.
You will need a Weight distributing hitch, no way around it. Not a Ram thing, all 1/2 tons need them.
Air bags do not at all perform the same function, with bags all the tongue weight is still only on your rear axle and the area behind the axle. Looks pretty but really no function. WDH does exactly what it says, distributes the weight along the whole chassis,which not only eliminates sag,but returns weight to the front axle. Makes for an incredibly stable towing platform. With a trailer that long you will also need sway control.
Old 06-09-2013, 09:48 AM
c4s c4s is offline
Vehicle: 2007 Ram
c4s is on a distinguished road
Sorry but this has been beaten to death on this forum and countless others. Go to some of the RV forums and do some research if you don't agree with me. You'll soon come to realize how important payload is. 9 times out of 10 you'll max out on payload long before you max out on tow ratings.
Think about it. You want 10-15% of your trailers weight on your truck. Most guys try to aim for around 12%. Let's assume you've got a 9000lb trailer (wet weight) behind you. That means you'll want close to 1100lbs on the tongue. That 1100 lbs is payload! You're already over your trucks limits and that is without any passengers, fire wood, dogs, bikes and whatever else a person might normally take with them when camping.
Even using your 9600lb rating above and setting it up so that only 10% is on the ball you've got 15lbs of payload left ...
Old 06-10-2013, 01:46 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:311
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
And the 985 lbs. of payload DOES NOT INCLUDE THE DRIVER. From my 2013 OM "The GVWR is the total permissible weight of your vehicle including driver, passengers, vehicle, options and cargo. The label also specifies maximum capacities of front and rear axle systems (GAWR). Total load must be limited so GVWR and front and rear GAWR are not exceeded. The payload of a vehicle is defined as the allowable load weight a truck can carry, including the weight of the driver, all passengers, options and cargo." Note: the only figure that Ram factors in 150 lbs. for the driver is the GCWR (Gross Combination Weight Rating). "The GCWR is the total permissible weight of your vehicle and trailer when weighed in combination. NOTE: The GCWR rating includes a 150 lbs (68 kg) allowance for the presence of a driver."
Using the 985 cargo capacity as an example and my weight of 185 lbs. I have 800 lbs. left that can be loaded on the Ram. Allowing for 12% hitch weigh, that means the Ram could tow a maximum of 6,667 lbs. with a hitch weight of 800 lbs. That is a significant amount less than the 10,000 lbs. the dealer may have told you that you could tow. If you carry passengers or anything in the bed your numbers will be lower. Sure you could tow 10,000 lbs. if you controlled your Ram by remote control and kept the hitch weight to less than 10 %.
Old 06-10-2013, 04:53 AM
madhatr02's Avatar
Rep:145
I agree 100%.
Nope the 985 is before you put a soda can in the truck.
My 2 points were quite clear I thought but I will rehash.
A. Payload is not towing capacity (never said they didn't effect each other but they are not the same as a few people said.
B. His towing capacity is not 1300 lbs as stated by c4s
Semper Fi,
Kevin
2016 Dodge Rebel
Old 06-10-2013, 08:50 AM
c4s c4s is offline
Vehicle: 2007 Ram
I agree 100%.
Re-read my post. I was referring to what I would guesstimate the payload was of his Outdoorsman. I didn't say his towing capacity was 1300lbs ...
"99% of the time payload capacity is the limiting factor when trying to figure out what you can tow in the real world. Yours being an Outdoorsman is probably not too bad. 1300lbs maybe"
Old 06-10-2013, 09:03 AM
c4s c4s is offline
Vehicle: 2007 Ram
Agreed! The only thing I'd add is that I think you can sometimes get away with a little less tongue weight when towing a boat. I think that must be what the manufacturer's are using when they come up with these crazy tow ratings? Because of the shape they are less susceptible to sway when compared to a box shaped travel trailer so you don't need to transfer as much weight to the truck in order for it to track down the road straight.
I won't pretend to be a boat towing expert though so those folks would have better knowledge than I when it comes to that!
Old 06-10-2013, 11:17 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
The tow/haul capacities on the Ram 1500's are pathetic. It just is what it is. I don't think people are buying them with much towing or hauling in mind. No way would I have bought one to do any kind of even semi-heavy towing or hauling on even a semi-regular basis. They ride really nice. They don't tow or haul worth a crap. Not compared to the competing half tons. But I wouldn't have ever bought ANY half ton to tow or haul anything substantial very often. That's what 2500 and 3500's are for...
- DAA
