Place your Ad Here!
Old 06-06-2013, 06:47 PM
RichardsonMedia RichardsonMedia is offline
Vehicle: 2005 Dodge Ram 1500
Color: Brown
RichardsonMedia is on a distinguished road
Default You are not going to believe this
I will make it as quick as I can -
I have a 2005 Dodge Ram 1500 with a 4.7. It started running hot - so I started working my way through the system. Ended up with a new radiator - fan clutch - water pump - thermostat - radiator cap. Still ran hot.
One day it ran so hot that - by the time i got off the road - it would not start. so now a have a reman engine in it with 3200 miles. (Had 114K when i put the new engine in)
So - in replacing the engine they guy took off the a/c compressor. i just got the a/c charged yesterday - and now the truck is overheating again - unless i run the heater.
when all of this started - it got to a point where i had to run the heater all the time to keep it from overheating - then it got worse. so it seems like im at that stage again... just waiting for it to get worse.
What could be causing it to overheat? i burped it yesterday - and could see the coolant moving in the radiator. the radiator does not have any cold spots. one odd thing is when it does get hot - and i have to turn the heater on - it does not really seem very hot. sometimes the heater is extremely hot - but not when the truck is running hot.
anyone want to buy a truck with a new motor? ....cheap
Old 06-06-2013, 07:05 PM
Rep:2906
I think that i would find a real radiator shop
not a shop that also does radiators
have them check it out & give you a opinion
If they say that you need to get it cleaned out, they could be saying that you need to get a regular flush, or cleaned out with Steam
Actually i would have them inspect it & get an opinion
if they say that it needs some work
Pull the radiator yourself & give it to them
Let them ROD it out, which involves removing the tanks & running a flat rod through the water passages of the radiator core, then they put it all back together & usually paint it.
You then put it back in your vehicle & likely never have to worry about it again
IF on the off chance they can't fix the issue, try to get a new CORE through the radiator shop, not from your local parts store
Good Luck
Old 06-06-2013, 07:22 PM
MOFOGO's Avatar
MOFOGO MOFOGO is offline
Vehicle: 2012 Dodge Ram RCSB
Rep:38
MOFOGO is on a distinguished road
If I understand correctly, you had no overheating with the A/C removed? And is that with the compressor OR the compressor belt off? Then with it reinstalled the overheating comes back? If so, I'd look at the clutch on the compressor to be sure it is engaging / dis-engaging properly and not creating excessive drag.
when all of this started - it got to a point where i had to run the heater all the time to keep it from overheating - then it got worse. so it seems like im at that stage again... just waiting for it to get worse. Also check your idler pulley, any drag on the pump drive can cause these kinds of problems.
If I understand correctly, you had no overheating with the A/C removed? And is that with the compressor or A/C belt off? Then with it re-installed the overheating comes back? If so I'd look at the clutch on the compressor to be sure it is engaging / dis-engaging properly and not creating excessive drag. And are you using a temp. gauge that you know is accurate? Also look for a collapsing radiator hose, I had this happen once and it took forever to catch. Good luck!
Old 06-06-2013, 07:29 PM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
If heater is blowing cool when engine is hot sounds like a flow problem to me. Did they put the old pump on the new motor?. May be defective.
Old 06-06-2013, 07:32 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Definitely have a flow problem if the heater blows cold. Could be your heater core is finished and its not allowing proper flow through the engine.
Old 06-06-2013, 07:44 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
X2 on the collapsed hose. I have seen this more than once. Also, are you losing any coolant? Are you running a 50/50 mix, or have you thinned it down to mostly water? Any antifreeze smell?
Old 06-06-2013, 08:10 PM
Color: Brown
Default thanks
the waterpump is new
the radiator is new
I didnt look,at the bottom hose but the top is fine
50/50 mix
not Losing coolant
the heat blows hot sometims. could there be an intermittent flow problem with the heater core? yesterday when I was burping it I had the motor running with the cap off. I could see the water churning.
if it were a flow problem turning on the heater would not make the engine get cooler would it
this really has me confused
Old 06-06-2013, 09:46 PM
Color: Brown
Default also
I forgot.to mention that the heater does.gurgle.sometimes
Old 06-07-2013, 05:56 AM
JWM59's Avatar
Rep:148
If hoses are fine I'm still leaning toward pump. Maybe a bad batch out there. If it has a gasket make sure holes are where they are suppose to be and they are open. Try running without thermostat to see if that is the problem also. I have put quite a few new parts on vehicles only to find out they are defective.
Old 06-07-2013, 06:23 PM
Color: Brown
Default How would I check the lower hose?
Upper hose seems fine. can I just crawl under there and rev the engine and look for buckling?
The hose is about the only thing I have not replaced. That and heater core.
dodge overheat bizzare
