Old 06-07-2013, 05:21 AM
danstanford danstanford is offline
Vehicle: 2013 Ram
Trim Level: Laramie Long Horn
danstanford is on a distinguished road
Default Alarm sounded, what did I do wrong?
Just loading all my stuff into the console and ramboxes when I thought I would see if I could start my new 13 without the fob. I went out with the key and unlocked her via the lock in the door handle but when I opened the door that damned alarm went off. Without the fob I couldn't turn it off till I ran back and got the fob.
What did I do wrong?
Old 06-07-2013, 08:00 AM
nikeman nikeman is offline
Rep:91
The keys are mainly for unlocking the door if you lose power and power locks won't work. The alarm arms with the door locks also. You can't start the truck with just the key either. There is a built in key in the fob itself also, assuming you do not have keyless enter and go.
Old 06-07-2013, 08:09 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Hi,
Yea, I did the same thing, opened the door with the key and the alarm went off. Hurried and put the key in the ignition and could not turn off the alarm. I had to run in and get the remote and press the unlock button.
I am glad it wasn't early in the morning. Getting to learn some of the new features and surprises.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 06-07-2013, 08:15 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Yup, the remote entry system with the FOB controls the Alarm, Also I think if you manually lock the door after some time it initializes the alarm automatically, you need the FOB to disengage the Alarm so it does not sound.
Old 06-07-2013, 10:20 AM
rb10475's Avatar
rb10475 rb10475 is offline
Vehicle: 2013 RAM 1500
Trim Level: Laramie Longhorn
Rep:33
rb10475 is on a distinguished road
Wow, I never realized there was a key built into the fab. Thanks!
Truxedo TonneauTrax & K&N Drop In & Bilstein 5100s
Old 06-07-2013, 02:32 PM
benajohnson benajohnson is offline
Vehicle: 2013 Ram 2500
Rep:36
benajohnson is on a distinguished road
So I take it unless you are keeping an extra FOB inside the cab, a hideaway key is almost pointless because you can't start your truck with the key?
Old 06-07-2013, 02:54 PM
Vehicle: .
Rep:4373
The key is really to get into the truck and pop the hood if you have issues like battery died, or you need to get shit out of the truck cause its dead and going to the dealer, stuff like that, many don't have the auto lock on the tailgate also, so the key will unlock that and allow you to get to your stuff.
Old 06-07-2013, 03:11 PM
Pantherjoe Pantherjoe is offline
Vehicle: 2013 1500 Ram
Trim Level: Big Horn CC
Color: Cherry red
Pantherjoe is on a distinguished road
I did the same thing the second day I had the truck. That is a crazy setup with the only being able to start the truck with the key fob. Salesman told me that to replace the key fob is extremely expensive.
You can tell if the alarm is set by a small red blinking light behind, I think tha tach gauge needle, but it is in a bad position to see it clearly... For theft deterrent purposes.
NewRamer
Old 06-07-2013, 03:12 PM
Rep:2657
I know that with my Ancient 2009 Ram
I have to insert my FOB into the ignition to Start & Run it
in the Fob there is a battery & small printed circuit board with a Memory Chip
On the big end of the FOB, there is a little slider that holds the SENTRY Key in place
The Sentry Key can be used in my Drivers side door & Tailgate Locking mechanism
with this type of setup, some people were breaking off the tip of the FOB, i believe that was in the 2008 & earlier models
a person had to get the broken piece out of the ignition switch & use their spare fob, if they had one handy, i heard that if it was not handy, there is another way to get the Ram started, you could take something like a popsicle stick or a small finger & push the wire in there forward & then turn the switch to the start/run position, the broken FOB had to be close to the switch
I believe that there is another type of key that can be used in place of the FOB, i have not seen one in person, i will see if i can find it online
https://ikeyless.com/vehicles/Dodge/.../2009/1001555/
Old 06-08-2013, 08:30 AM
Vehicle: 2013 Ram
OK, suppose I lose my fob but I have my spare key in a lock box, does this mean I cannot get into the truck without setting off the alarm? And if I do have to get into the truck to get my phone, for example, I cannot turn off the alarm?
To confirm, I cannot start my truck without the fob? What if the batteries die?
