New Wheels - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-07-2013, 11:41 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default New Wheels
Hey guys i was curious if it matters whether i get hub centric rims or lug centric rims? I think the stock rims are hub centric, does this mean i have to get hub centric wheels?
Thanks
Old 06-09-2013, 12:52 PM
punisher69's Avatar
punisher69 punisher69 is offline
Vehicle: 2012 Ram
Trim Level: slt crewcab 4x4
punisher69 is on a distinguished road
Most aftermarket rims are not hub centric,they make the hub hole larger to fit a wide variety of hubs.What you do is buy hub centric rings,these are usually plastic or aluminum and fit on your hub to make a tight fit when the wheel is put on.This eliminates any vibration you might get when installing new wheels.I found a set on Ebay for 15$.
Old 06-09-2013, 03:19 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Right. Most all aftermarket wheels are lug centric. If you have any vibration issues, hub centric rings could solve them.
2012 Ram 2500 4x4 ST Crewcab, Cummins 6.7, RCX 5 inch lift, 22x12 Fuel Mavericks, 35 inch Toyo MT's, H&S XRT Programmer, MBRP exhaust
Old 06-09-2013, 03:44 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
I always make sure to use them on my trucks. although wheel shops will say that it isnt 100% needed as they are lug centric
Personally, I do not like the wheels to rest on the lugs.
I would say get the hub centric rings
sales@revelperformance.com
Old 06-10-2013, 03:24 PM
Trim Level: express
Rep:43
Where is a good place to get hub centric rings?
Old 06-10-2013, 03:48 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
i got mine from JEGS...haven't installed them..bought them months ago. I'm just too lazyyy
Old 06-10-2013, 04:16 PM
Revel Performance
Rep:1804
Gorilla is also another or even Ebay
All you need to know is the inner diameter of your rim and the outer diameter for the hub on the truck which is 77.8
Old 06-10-2013, 04:42 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
My Fuel Hostage wheels came with the hub centric rings. Have you gotten your wheels yet to see if they come with?
Old 06-10-2013, 07:56 PM
Trim Level: express
Rep:43
I am looking at the fuel octane rims and on the website i am going to buy them from it says: HUB CENTRIC: NO. I am amusing that means that it does not come with the ring.
Old 06-10-2013, 08:03 PM
Revel Performance
Rep:1804
Buy the wheels from us and I will make sure you get hub centric rings and the correct ones as well
Send me a PM or email if interested
