Old 06-08-2013, 08:54 AM
kbr577 kbr577 is offline
Vehicle: 11 Ram 1500 Outdoorsmen
Color: Deep water blue
kbr577 is on a distinguished road
Default Water leak
I have a water leak in my 11 QC,both sides of the rear headliner is wet! Anyone have this problem? It must be the third brake light or the rear window.
Old 06-08-2013, 09:16 AM
Rocky Harbour Rocky Harbour is offline
Vehicle: 2010 Dodge 1500 Ram - Quad Cab
Trim Level: TRX 4 Off Road
Color: Brilliant Black Crystal Pearl / Light Greystone Pearl
Rep:26
Rocky Harbour is on a distinguished road
You are correct. The usual suspect is the third brake light. However it could also be the seal around the rear window. I taped over my third brake light and sprayed water over the window to see which one may have been leaking. It was my third brake light.
Old 06-08-2013, 09:26 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
easiest to check is the third break light.
Old 06-08-2013, 10:23 AM
When I get out of work,I'll check the break light first!
Old 06-08-2013, 11:41 AM
Asur Asur is offline
Vehicle: .
Rep:4373
I don't have this issue on my 2012 yet, but wonder about that foam piece that the light has against the cab to stop that from happening, I wonder about adding maybe a line of Zip Clear silicon all around the area that is stuck to the cab. Would have to remove the light and add that, anyone do this?
Old 06-10-2013, 06:13 PM
scasselin scasselin is offline
Vehicle: 2011 Dodge Ram 1500
Color: Hunter Green Pearl
scasselin is on a distinguished road
I had same problem on my 2011 CC, water leaking from both sides of headliner. took it back to dealer and it was the third brake light, they replaced under warranty and problem solved. they said they are getting a lot of these coming into the shop.
Old 06-13-2013, 04:55 PM
shostopper17's Avatar
shostopper17 shostopper17 is offline
Vehicle: 2011 Dodge Ram Express
Trim Level: 1500 Express
Rep:54
shostopper17 will become famous soon enough
same here happend about 3 months ago but the dealership fixed it no problem
Old 06-13-2013, 10:02 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Most likely the 3rd brake light. Especially if it's dripping from the corners of the headliner. See this fix(I wouldn't waste the time at the dealer, it's a ~$10 and 15 min fix):
http://ramforumz.com/showthread.php?...ght=brake+leak
Sean
