Old 06-08-2013, 11:07 AM
vonirkinshtine vonirkinshtine is offline
Vehicle: 2005 Dodge Ram 1500
Rep:38
vonirkinshtine is on a distinguished road
Default Main firewall bulkhead grommet replaceable?
So...long story short, is the big, main, rubber firewall grommet on the driver's side of the engine bay (see attached picture) replaceable?
(2005 Ram 1500 SLT, quad cab, 4.7L, 4WD)
Old 06-08-2013, 11:38 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Technically, yes. However, to do it correctly, you'd have to remove the wire harness. I'm thinking you could probably cut the grommet on one side to fit over the harness and then seal it with some crazy clue or something that will fuse the rubber together.
Old 06-08-2013, 05:50 PM
Rep:38
I'm digging through my Service Manual and I can't find anything that talks about removing that harness (pulling it back through the firewall). I'm sure it's in there somewhere.
Is it as simple as the main bulkhead connector (C219 I think the connector number is) will pass through the firewall with the grommet removed?
Old 06-08-2013, 11:01 PM
Rep:2929
Will it pass through with the grommet removed? I would imagine so, but don't know for sure since I haven't done/seen it, but I'm guessing that when they built the truck they put it through there.
