ZDOG
Old 06-19-2013, 10:39 AM
heath.robertson heath.robertson is offline
Vehicle: 04 Ram 1500 Quad Cab HEMI 5.7L
heath.robertson is on a distinguished road
Default Spare Tire Tailpipe Clearance Question
On Friday I got a 2004 Dodge Ram Quad Cab SLT!
It didn't come with a spare, so I went to the local Dodge salvage yard and got one that will work with my 20" wheels.
They put it up, and when I got home I started looking at it. Then I noticed how alarmingly close the tailpipe is to the spare! I'd say I have no more than 1/4" clearance between the tailpipe and the spare. I shifted the tailpipe around as much as I could, and it would never make contact, but it was very close.
Is this going to be a problem, or is this normal?
Thanks for your input!
Old 06-19-2013, 12:07 PM
Rep:2080
I'm not sure what the normal set up on the 3rd gens is but I know on my 4th gen the tail pipe is way further away from the spare and there's still a heat shield to block it. I would definitely be a little concerned with your set up.... Hopefully another 3rd gen member can chime in for you to see what there's looks like.
Old 06-19-2013, 01:51 PM
Well darn...
My tailpipe could be bent out more to the right and still not protrude from the truck body, so I'm thinking that my best option may just be to go to a muffler shop and see what it would take for them to bend it out of the way.
That way I could keep the spare in the stock position, and not have to worry about it melting. Seems like the simplest solution to me, while still keeping the spare out of the way.
Old 06-19-2013, 02:29 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Trim Level: ST express
Color: Grey
Rep:195
If it's not actually touching the tire you should be fine. Think about how much heat is generated just from a tire driving on hot asphalt on a road trip! Also, the exhaust isn't incredibly hot by the time it gets that far back.
Old 06-19-2013, 03:25 PM
namretsud's Avatar
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:196
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
When lifting the tire into place , pull the tire away from the exhaust as you winch it into place and you should get more clearance, and it will stay put when you snug it into place.
Old 06-19-2013, 10:00 PM
That sounds like the kind of simple solution I like!
I'll try that and see how it works.
Thanks for all of the input!
Old 06-21-2013, 11:17 AM
I did this last night, and it gave me at least an additional inch of room! I'm much more comfortable with where it is now, and I like the simple solution!
Thanks so much!
