Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
tonneaucovered.com
Old 06-09-2013, 02:59 AM
Venomouslou's Avatar
Venomouslou Venomouslou is offline
Vehicle: 2013 RAM 1500
Color: BLACK
Venomouslou is on a distinguished road
Default Mopar oil filter part number
Im changing my oil and i need to know the part number for a mopar filter for my 2013 5.7 hemi ram express!
2013 Black RCSB 2WD 1500 EXPRESS
Old 06-09-2013, 07:38 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I believe that the MOPAR filter part number is listed in the look up book at most parts stores.
Part# 4884899AB
The above info found here
Exco
Bill
Old 06-09-2013, 10:56 AM
Color: BLACK
It is not. Only up till 2011. Is it the same?
Old 06-10-2013, 02:43 PM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Get a REAL Oil filter
Firstly, MOPAR doesn't make oil filters. That filter is a re-badged, re-colored, re-logo'd FRAM or STP or such.
Get a MOBIL 1 oil filter, a Royal Purple or K&N filter. Even the newest TOP end FRAM (which I'm evaluating on both my cars) will keep the oil cleaner longer and actually FILTER the oil with filtering media instead of dribbling the oil over cardboard.
Old 06-11-2013, 02:11 AM
Color: BLACK
I ended up getting mobil 1 ..
Old 06-11-2013, 02:49 AM
Tcon Tcon is offline
Vehicle: 2013 Ram 1500 QC 4x4 Sport
Rep:49
Tcon is on a distinguished road
Just a heads up, I have the hemi + 8 speed and the listed mobil1 m1-210 did not fit on my truck. The opening size and thread pattern was different.
5.7L/8 Spd/3.92/Air Ride - Whited Out Badges - S&B CAI, 87MM TB, BT Catch Can, Magnaflow 22", Magnaflow Y Pipe, Weathertech Vent Visors, White 3" Stubby Antenna, DeeZee Tailgate Assist, Bak Flip G2
Old 06-11-2013, 09:19 AM
Brandon .30-06 Brandon .30-06 is offline
Rep:29
Brandon .30-06 is on a distinguished road
You need a big black one.....sorry inside shop joke
Old 07-20-2013, 02:00 PM
Bluetoof Bluetoof is offline
Trim Level: SLT Crew Lonestar
Color: Blue
Rep:21
Bluetoof is on a distinguished road
Autozone gave the M1-210 and when I took it home I noticed it was quite a bit bigger then the stock filter. I took the number on the stock filter which was 04892339aa and when I returned the M1-210 I had them cross reference the stock number. It came up with M1-113. This filter looks to be the right one, hard to believe this big motor uses such a small filter.
5.7L/8 Spd/3.92 - BAKFlip FiberMax
Old 07-22-2013, 10:54 AM
pcb50 pcb50 is offline
Vehicle: 2013 ram 1500 longhorn
Trim Level: longhorn
Color: maximum steel
pcb50 is on a distinguished road
My dealer is Ford/Chrysler-Dodge-Jeep, and when I had first oil change done in my '13 Longhorn, they used Motorcraft 5w20 semi-synthetic oil and Motorcraft Fl-820s filter. Saves them stocking two lines. Just FWI. Paul.
Old 07-22-2013, 02:54 PM
Rep:2737
Personally i use these brands, they are all made by WIX
WIX 57899
Carquest 84899
NAPA 7899
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
