Old 06-09-2013, 02:52 PM
68gtx 68gtx is offline
Vehicle: 2013 dodge ram sport
Trim Level: sport
68gtx is on a distinguished road
Default 2013 ram sport towing capability
this is my first post as a new ram owner, great site,. after doing some reading on here i have a concern as to the towing capcity of my new truck.. my new ram sport has the 8 speed trans with 3:55 gears , what can i tow??? delaer told me 10,000lbs, i am concerned that may be wrong?. cant find anywhere exactly where it tells you?
Old 06-09-2013, 03:18 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
With a 3.55 rear max tow is around 8500 lbs.
Check this section you posted in as it contains several posts about the information you are seeking. You can also go to the Ram site and it will have a section on towing limits.
Old 06-09-2013, 03:38 PM
nikeman nikeman is offline
Rep:91
Think the 3.92 tows 10,000 lbs so that's prob what your dealers referring to.
Old 06-09-2013, 05:19 PM
Warwagon's Avatar
Warwagon Warwagon is offline
Vehicle: 2015 Hellcat
Color: Sublime pearl green
Rep:71
Warwagon will become famous soon enough
With the hemi and 8 spd the factory says .....
3:21 = 6550lbs tow rating
3:55 = 8700lbs tow rating
3:92 = 10,000lbs tow rating
The above is a general rule of thumb as every truck configuration can be slightly different depending on options
Aspire to inspire before you expire
Old 06-09-2013, 05:30 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
The above posted towing specs are pretty darn close, if not spot on. To make sure the best place to check is the sticker in the drivers door which also indicates the weight of your truck, gross vehicle weight etc. air pressure. The information on the sticker is specific to the build of your truck. When the dealer told you 10,000 pounds, either he did not know, telling you anything to make the sale or was confused. Generally the 10K rating is with the 3.92 gears.
Old 06-09-2013, 05:43 PM
OAG18 OAG18 is offline
Vehicle: 2013 Ram 1500 4x4 cc
Color: Maximum Steel
OAG18 is on a distinguished road
I don't care what the specs say. I would never tow 10,000lbs with any 1500 pickup. I don't care what manufacturer. You may be able to pull 10,000lbs, but you cannot safely stop and control that much weight with the weight of a 1500 pickup.
Old 06-09-2013, 05:47 PM
Brians RT's Avatar
Brians RT Brians RT is offline
Vehicle: 04 Ram 2500 4x4 RCLB 13 Ram RT
Trim Level: SLT, RT
Color: Atlantic Blue/Silver, Bright White
Rep:39
Brians RT is on a distinguished road
If the trailer has good brakes sure you can.
04 Ram 2500 4x4 RCLB Hemi A5 4"lift 35's
13 Ram R/T Bright White
Old 06-09-2013, 05:49 PM
kev12345 kev12345 is offline
Trim Level: Sport 4x4
Rep:14
kev12345 is on a distinguished road
Agreed. I'd sacrifice a bit of towing capability for ride comfort and mpg anyway. if you're doing serious towing, get a 1 ton.
Old 06-09-2013, 09:10 PM
Rep:2559
When towing a fair load, trailer brakes are a must, or as OAG18 indicated stopping would be a real concern.
Old 06-09-2013, 10:19 PM
bigbody's Avatar
bigbody bigbody is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Black/gray
bigbody is on a distinguished road
Don't think stopping a 10k load with a 1500 would be much different than stopping 30k load with a 3500, if done properly with trailer brakes and proper weight distribution shouldn't be a problem, although the op was just asking what the capacity was not saying he was hauling that much
2013 RAM 1500 Laramie, sunroof, 3:55gears, undercover se, avs in channel, 30% tint all around
