Old 06-09-2013, 04:50 PM
jdip jdip is offline
Vehicle: 2014 Ram 1500 Crew Cab
Trim Level: Sport 4x4
Rep:26
jdip is on a distinguished road
Default Need to make my own Tailgate Lightbar Trailer Plug
I am looking at buying a tailgate lightbar but its home made and doesnt include a plug and play connector. I looked into all the big name brand ones, really liked the Recon but did not like the amber scanning turn signals and wanted red. But not a fan of the plasmaglows red scanning turn signals. This one actually does progressive turn signals, which I am a big fan of. Its a 3 piece set that has a middle (tail and brake only) and left and right piece (both ends have tail/brake/and signal)Is it possible to add one on my own when I get it. I am still clarifying with the seller if each piece will have to be tied in, or if they are already connected to one wiring harness.
Thanks! Hope everyone had a good weekend.
Old 06-09-2013, 08:09 PM
Asur Asur is offline
Vehicle: .
Rep:4373
just get a "t" connector for your truck and splice your light bar into it, use shink wrap and dialectic grease, will make a nice clean job behind the bumper and you wont cut into the trucks OEM wire harness.
Old 06-09-2013, 08:22 PM
Rep:26
Awesome I was planning on getting one of those anyway. So where the pigtail plug is just cut the plug off and connect the wires? Do you happen to know which one is which. (Obviously not on the light bar but on the harness/plug)
Old 06-09-2013, 08:38 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Hopefully this helps:
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 06-10-2013, 01:36 AM
Rep:26
Yes it does thanks! Just making sure I'm correct. White is ground green in r turn yellow left turn. And a little confused. Does red go to both left and r side stop and brown goes to both left and r side tail/running ?
Thanks!
Old 06-12-2013, 01:39 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Thanks!
No, the red (stop) and brown (taillight) only connect to one side to draw power.
Old 06-12-2013, 10:17 PM
Rep:26
Per the seller ill only be able to attach te stop/tail to the harness. He says the signals will require a source that does not combine the stop or tail with the signal. Is there any other way to connect this then aside from hard wiring it? Will the 7 pin connector work for this? So in summary looks like I can have all 3 strips wired together for stop and tail but both signals need to have independent power.
Old 06-13-2013, 12:53 PM
CaptDuff CaptDuff is offline
Color: True Blue Pearl
Rep:159
CaptDuff has a spectacular aura aboutCaptDuff has a spectacular aura about
http://www.dirtpartsdepot.com/servle...p--Jeep/Detail
I have something like this for a project I am going to do eventually, to separate out the stop and turns from a 4-wire plug coming off of the t-connector I have yet to buy.
Would have found an ebay link, but apparently ebay is down?
Old 06-13-2013, 05:58 PM
Rep:26
http://www.hopkinstowingsolutions.co...ble_3_ft_.html
I have the combo 7 pin/4 pin on my truck now. Assuming the 7 pin does the left and right signal separately which I think it does (someone confirm please) ill just get a new t connector instead of the 4 pin one and just have 2 7 pin connectors and use this to run to the bar and just cap any of the extra wires I don't use. Am I on the right track now?
Old 06-13-2013, 06:09 PM
Vehicle: .
Rep:4373
here you go
